Can you tell me what bits you're using? I've just recently got a 6040 and interested in giving it a try...
Bits as in "tooling", or bits as in "bits & pieces"?
I'll asume the latter, but any more detail needed just ask.
On my primary 6040:
- ripped out all the cheap cabling and replaced it with shielded cables
- put the Chinese stepper drivers aside and replaced with a Gecko G540
- got a USB smoothstepper, but currently still using Mach3 (or grbl) via parallel port
- threw away the awful spindle controller & brushed spindle, and replaced it with a brushless one [1]
- added a pair of Meanwell 350W 48V PSUs
- added a decent E-stop button that is easy to access
- made clamping bars using 1" square steel tube, 6mm threaded rod, & wing nuts
- got some proper T nuts (M6 ones for a Sieg mill)
- plastic (HIPS 10mm) sacrificial bed that covers the useable work area, and milled flat as needed
- added some limit switches, but they're not currently wired
- two different pendants - a Modbus one with MPG [2] (unused) and a brilliant but simple USB one [3]
- purchased a huge variety of PCB drills and small milling cutters over the last 10 years
- vacuum cleaner - quite critical! I use a small Ryobi one
- also had several attempts at a spindle dust collector, but not found a good compromise for my usage
In reality, it is all about what you want to do with it.
I mill lots of plastic and Aluminium parts for front panels, prototype mechancial parts, small production runs of parts for scientific instruments, plus the odd PCB and test jig.
[1] This is the brushless spindle I'm using:
www.ebay.com.au/itm/121581247413It is a little gutless, but at least it doesn't keep blowing fuses, wearing out brushes, and generally trying to electrocute me.
Every now and again the new one will slow down for a second and then restart. I suspect a compatibility or configuraion problem with the G540 PWM output.
If it does that at just the wrong time it can break a tool
so I really need to put a scope on the PWM and enable signals and find the culprit.
[2]
www.homanndesigns.com/index.php?main_page=product_info&cPath=54_15&products_id=74[3]
https://www.kickstarter.com/projects/1651082654/jog-it-open-source-controller-pendant-for-emc2-and
