Author Topic: Glossy vs matte solder mask  (Read 3186 times)
Offline derGoldsteinTopic starter
  • Country: il
    • RapidFlux
« on: October 19, 2017, 08:46:15 pm »
A typical glossy solder mask is quite resilient to scratches and physical damage. Is a matte solder mask more or less resistant? I'm wondering if, given a lot of part reword and replacement, the matte versions are more susceptible to the solder mask scraping off.
In some close-up photos the matte solder mask seems to hide scratches better, while in others it looks like it's a scratch magnet. It's probably different between manufacturers, but I'm wondering if there's a rule of thumb.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Glossy vs matte solder mask
« Reply #1 on: October 19, 2017, 09:54:58 pm »
I've had the experience that glossy tends to be weak.  I've seen some strong glossy too though, so it's not a rule.
That's probably more just because, the matte boards tend to be from production lines, where they follow the specifications precisely.
Cheap protos usually use cheap soldermask, and the cheap stuff just happens to be glossy, no surprise there.
There might be something about a matte surface holding flux better, and therefore something or other about paste coalescence.  Idunno.
Seven Transistor Labs, LLC
The following users thanked this post: derGoldstein
Offline Yellofriend
  • Country: hk
« Reply #2 on: October 20, 2017, 01:21:50 am »
I would always prefer matte. Glossy is irritating when you do manual rework on a PCB. Picture taking is also more difficult with all the reflections.
TVM802C - now with OpenPnP
T962A
Offline Mattylad
« Reply #3 on: October 20, 2017, 07:18:06 pm »
I found glossy to be too reflective and confusing the pick and place camera systems.
So insisted on a matt finish only.  :-+
Matty
CID+
Offline zeqing
« Reply #4 on: October 27, 2017, 08:58:06 am »
the matte solder mask would be more expensive as they are not so pupular used.
