Author Topic: Heavy Duty Header - Sourcing this part  (Read 1720 times)
Offline dapugTopic starter
« on: March 30, 2017, 08:44:27 pm »
I'm looking for this female connector (see attached pic):
This is not your cheapeie 1x8 female header:
Notice the contacts on the first pic are all the way to the surface, and they are pretty beefy, versus the regular header.
But I cannot figure out what this is after lots of searching through digikey, mouser, etc. It is similar to a swiss header, but is obviously reinforced SQUARE rather than round pins.
Anyone ever used or seen something like this?
« Last Edit: March 30, 2017, 08:53:57 pm by dapug »
Offline Kean
    • Kean Electronics
Re: Heavy Duty Header - Sourcing this part
« Reply #1 on: March 31, 2017, 01:01:59 am »
Never seen a socket like that with square contacts, but a round machined pin socket like this will take 0.1" pitch header pins
http://au.element14.com/fischer-elektronik/bl5-36z/header-socket-2-54mm-36way/dp/9728910
http://www.fischerelektronik.de/web_fischer/en_GB/connectors/G02/Female%20headers/PR/BL%205/$productCard/parameters/index.xhtml
They have much better retention force than the cheapies, and better current ratings.  Strangely this one is not listed on Mouser or Digikey.
I can dig out part numbers for similar 2mm pitch connectors if yours are something other than 0.1"
