Author Topic: Higher resolution (but inexpensive) "microscope" camera  (Read 5091 times)
Offline forrestcTopic starter
« on: September 27, 2018, 10:59:47 pm »
On the manufacturing line, I'd like to add a step where we take a high resolution picture of each board/small panel just before it gets the connectors put on.   Possibly do some vision inspection at the same step.
To accomplish this, I'm hoping to find an appropriate high resolution camera/lens combination which can be easily mounted on a stand.    I'm tempted to pull the trigger on the $500 microscope camera Dave just did a video on, but I really would like something where I can snap a bit higher resolution picture and then store that image with the traceability data on the products.    I note that there are several non-autofocus  cameras out there up to 16mp, perhaps more.     At the bare minimum I could take one of these, stick a wifi card in the sd slot (possibly using an adapter), and grab the images automatically that way.   But I'd rather be able to do it through usb or other less-finicky options.
Cost is always important, but tempered with the fact that time is money too....
Anyone have good luck with any particular cameras doing this type of stuff?
Offline mrpackethead
  • D Size Cell
Re: Higher resolution (but inexpensive) "microscope" camera
« Reply #1 on: September 28, 2018, 12:41:19 am »
I'd love to put several of these in my line.. One post solder paste, one before reflow and one after reflow.    Software is a real challenge as well.
  • D Size Cell
« Reply #2 on: September 28, 2018, 01:02:41 am »
That's why they have AOI and AXI.
IN deed. But it comes at a price that is way too high.
« Reply #3 on: September 28, 2018, 03:03:52 am »
And the ones which are at least somewhat in reach price-wise tend to be way too slow.     I've done various analysis of cost savings/defect savings/etc, and we just don't have enough volume or a high enough defect rate that we want/need a full AOI or an AXI.   If I ended up with a decent higher resolution camera, I might consider writing a bit of code in opencv to look at the common fault locations in an automated way, but that's just a bonus.
Right now, I just want an image of the board to add to our existing ATE data we collect for every board which goes out.   But it needs to be high enough resolution so that you can actually see the individual pins on reasonably fine pitch TQFP's and the like.
  • D Size Cell
« Reply #4 on: September 28, 2018, 05:29:45 am »
Why do you want to collect image data?  That intriges me.
Offline Berni
  • Country: si
« Reply #5 on: September 28, 2018, 06:01:07 am »
Having photos can be useful later when things go wrong.
You can look at the serial number of the problematic board and go find photos of it in the production process. Especially if the boards are given to a client for final installation.
« Reply #6 on: September 28, 2018, 07:38:30 am »
A few times a year we get a return which we wonder for various reasons we would like to know the status of the board before we sent it to the customer.  Mainly it's things which are causing flaky in-field failures which sometimes are caused by something we missed during inspection, such as a missing regulator cap or a bridge in a spot which doesn't cause the board to fail test, but causes an in-field failure.   We've found that having a customer send a picture of an in-field circuit board helps greatly with troubleshooting, assuming they can get enough resolution.   I'd like to be able to supplement this with these images (perhaps to look at before we get to that step).
My hope is to find some way to collect the images in a low-time-impact manner.   I'm still working through the details, but one thought would be if we can replace the pcb barcode scan step at certain spots in the process with a high resolution camera (which also captures the barcode information) then we can gain this imagery effectively for free time-wise.
Another place where we think this might be useful is if you capture pre- and post-rework imagery, and you have a problem, you can not only see that the board was re-worked but what might have changed in before and after images.   I'm sure there are lots of other applications which will present themselves.    One in particular I might end up playing with is described at http://www.bobbaddeley.com/2015/12/06/creating-an-automated-optical-inspector-for-50/
One thought I've come back to a couple of times is to get an older DSLR and an appropriate lens and mounting apparatus.   For instance canon DSLRs have fairly decent USB support in python which would allow me to capture an image.   But I'd really rather get something a bit simpler to deal with.
  • D Size Cell
« Reply #7 on: September 28, 2018, 09:17:45 am »
Im going to be moving our factory line soon, and i'll be inserting some slightly longer conveyors inbtween the machines.  A bit of thought for this, now might save some time later.
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #8 on: September 28, 2018, 09:36:16 am »
Maybe a consumer digital camera would be useable for this ?
Day Job: Mostly LEDs
Offline Domagoj T
  • Country: hr
« Reply #9 on: September 28, 2018, 08:59:17 pm »
A project I've been working on for the last year or two (read: has been sitting in a drawer in half assembled state) is a USB web cam with a manual SLR lens.
You can pick and choose which USB camera you want to use, but its lens should be removable. Some are glued in a way that it's hard to detach it from the sensor without damaging it. Avoid those.
A manual full frame (it could be APS-C lense too, it really doesn't matter) 50-100 mm prime (not zoom) lens will give you exceptional magnification and working distance. Nothing I've seen on the market comes even close to the Canon 100 mm Macro lens regarding magnification capabilities and focus distance. Unfortunately, it's not manual so it's tricky to adjust aperture. The manual lens l have is, IIRC, 85 mm which is a bit less flexible in terms of focus range, but still more than serviceable (the Canon one has unusually large focus range).
I've also tried zoom lenses, but the ones I've tried had much narrower focus range and were less suitable.
The downside is the USB connection on the web cam I have, which has a bit of a lag. Also the image quality is not as crisp as you can get, but the camera was only about $30, so what could you expect, right?
Offline Kleinstein
« Reply #10 on: September 28, 2018, 09:42:08 pm »
A board inspection is more really microscope, maybe not even a true macro. A reasonable close up function should be sufficient. Good lightning is also important.
There is a chance some consumer camera could work (e.g. 16 MP sensor). It's just finding one that also works well as a web cam, e.g. picture transfer and supply via USB.  Even an older/low end DSLR model might work. With a large SD card one may even consider just changing that card every day / weak, after a few 1000 pictures.
  • D Size Cell
« Reply #11 on: September 29, 2018, 04:26:12 am »
I had a play with that software suggested above, but other than that, i have yet to find anythign else.     I DIY AOI system would be awesome.
Offline Berni
  • Country: si
« Reply #12 on: September 29, 2018, 09:32:54 am »
Using it a sensor as a webcam starts to become problematic at such resolutions.
Getting 1080p 60fps to fit over USB pretty much requires USB 3.0 already. You can fit 1080p 30fps over USB 2.0 with enough compression, but having too much other crap on USB can screw it up already. And this is only 2 Megapixels.
At 16 Megapixels that's a lot more data, even with fast transfer speeds its difficult to get more than just a few frames per second. So consumer digital cameras have a good reason for not supporting webcam mode. Its not as simple as connecting USB to the CPU and writing a bit of software.
The best bet is probably using a cheap DSLR or mirrorless camera. They often have remote control capability where they can be connected to a PC in some way and allows remote setup and shutter triggering and then retrieve the final image. Photographers sometimes use such functionality when shooting on a set to make things more convenient. You can probably trigger the camera pretty precisely so that the board doesn't have to wait for long for its photo. If very bright lighting or a flash is used then the board can be imaged while its still moving on the conveyor. The camera can likely spit out JPEG rather than RAW too so you already have the image in a good format for archival. Yes JPEG is lossy, but it does a great job of shrinking down photographs while still looking good enough when the quality is set reasonably high.  When you take thousands of photos per day it really does matter a lot if the photos are 5MB or 200MB
Offline Smallsmt
« Reply #13 on: October 01, 2018, 11:14:41 am »
We are doing just now
https://twitter.com/SMALLSMT/status/1046411818959343617
  • D Size Cell
« Reply #14 on: October 01, 2018, 07:43:13 pm »
You've been doing a lot of things for a long time. We've seen lots of high resolution renders, and lots of pics of Chinese machines that you import and rebrand.      With the 20+ staff you've got in your facility in Germany plus the extensive network in China, you should have this done soon I' sure.    Right after you've finished the machine that will only be another month away.   :-)     What the heck was the point of your post.
Offline Smallsmt
« Reply #15 on: October 01, 2018, 08:19:50 pm »
Nice you are my new product manager ;)
  • D Size Cell
« Reply #16 on: October 01, 2018, 08:43:02 pm »
My first job would be to peformance management delivery of promises.
The following users thanked this post: Smallsmt
Offline Smallsmt
« Reply #17 on: October 01, 2018, 09:02:32 pm »
I think we delivered already a lot of good products and ideas.
No other chinese PNP manufacturer has wider product range.
If you need to buy our german PNP machine you should look for ATN in Berlin they prepare a new machine soon using our mechanics.
And believe me if I will finish the development too step by step!
But now we are able to deliver a very good machine called VP-2800HP-CL64 doing mostly the same job.
We finished the development in summer this year when I stayed in China for 3 weeks.
Now we add PCB inspection systems and reflow oven to our product rangeĀ“.
Yes the reflow oven is rebranded like all other factories do too but we improved the oven to meet the CE!
And finally we do the customer service and care the warranty.
Offline Kjelt
« Reply #18 on: October 02, 2018, 08:28:46 am »
Back ontopic, will one picture tell the whole story?
As could be seen in Daves $500 camera video the tombstoned cap could not be identified from a single picture from above.  ;)
You need at least one more picture from an angle, better a few different angles.
  • D Size Cell
« Reply #19 on: October 02, 2018, 08:35:23 am »
on all but the smallest boards, its going to need more than one picture to be able to look at the entire board, to spot issues, it strikes me that it may be more cost effective and a whole lot easier to have an array of low cost USB cameras, than to have one that moves around...
Offline Smallsmt
« Reply #20 on: October 02, 2018, 08:41:44 am »
We use multi angled and multi color light first.
One option is to move the PCB in different angles under the camera.
The next upgrade is a 4 camera system but it's not a cheap system.
Offline Kjelt
« Reply #21 on: October 02, 2018, 08:53:09 am »
Yes or rotate the board while it passes the camera, could be an option.
If time is critical combine it with another step in the process like after loading it in the flying probe tester or exiting the reflow oven.
Offline b_force
    • One World Concepts
« Reply #22 on: October 02, 2018, 09:01:49 am »
I don't see the problem?
Get some macro extension tubes (for 30 bucks incl AF) with a decent lens and decent mirrorless or DSLR.
Nowadays there is plenty of software that let you control everything.
Especially just taking stills is not a big issue at all.
Don't forget to mount a polarizer as well.
  • D Size Cell
« Reply #23 on: October 02, 2018, 09:07:12 am »
I figure a Panel of up to A4 size could be imaged by 12 USB ( 4 x 3 ) cameras very cost effectively. I imagine them being around 200mm above the pcb..  The cameras are cheap ( 20-30 USD in china ).
Offline b_force
« Reply #24 on: October 02, 2018, 09:15:05 am »
Here an example how you can even control it with a raspberry.
Hook it up to you LAN and you can even use it remotely
https://youtu.be/1eAYxnSU2aw
Another idea is using a USB capture card.
Or use a dedicated card if you build a system anyway
(Which are a lot cheaper)
« Last Edit: October 02, 2018, 09:31:47 am by b_force »
