Author Topic: Is there a standard name or code for this USB socket?  (Read 2404 times)
Offline derGoldsteinTopic starter
  • Country: il
    • RapidFlux
« on: February 25, 2017, 06:00:48 am »
I've been looking for a completely SMT USB type-A sockets, and found these:
http://www.mouser.co.il/Search/ProductDetail.aspx?R=KUSBEX-SMT2-AS1N-BTRvirtualkey51700000virtualkey806-KUSSMT2AS1NBTR
https://www.arrow.com/en/products/uj2-ah-1-smt-tr/cui-inc
They use the same footprint, which is the same you can find on ebay like these:
http://www.ebay.com/itm/100Pcs-USB-Type-A-Female-4Pin-SMT-Socket-Solder-Connectors-/181632047439
Is there a name for that particular model or footprint? I'm trying to compare prices but just setting "USB type-A female SMD connector/socket" in parametric searches gives me a lot of sockets that have prongs sticking through the PCB, which I can't use (the bottom of the PCB should be flat).
I have the Kycon ones, and the ones from E-bay, and the're almost exactly the same in their dimensions (except the ones from E-bay are janky and made from a ferrous metal). Would these dimensions or footprint be standardized?
  • Country: il
    • RapidFlux
Re: Is there a standard name or code for this USB socket?
« Reply #1 on: February 25, 2017, 08:22:12 pm »
That's a type B (standard one, not mini/micro ones) USB connector, also called printer connector.
I assume you looked at the photo at the top of the Kycon datasheet? Scroll down to see the drawing, it's a type-A.
Online wraper
  • Country: lv
« Reply #2 on: February 25, 2017, 08:42:41 pm »
It's not really widely used and I would suggest avoiding using it if you are designing it into a new product. Easy to knock it off the board together with pads. There is no standard name AFAIK.
Offline donotdespisethesnake
  • Embedded stuff
« Reply #3 on: February 26, 2017, 02:11:23 pm »
Agreed and probably why there are not many of that type around.
You need to redesign your product, or it will fail.
Bob
"All you said is just a bunch of opinions."
Offline andersm
« Reply #4 on: February 26, 2017, 06:41:08 pm »
Most surface-mount USB connectors will have small plastic nubs for alignment, but unless you're using some crazy-thin PCB the won't stick out the underside. Consider using a panel mount connector for better mechanical durability.
  • Country: il
    • RapidFlux
« Reply #5 on: February 26, 2017, 10:06:02 pm »
Yeah, the ones I'm using now have them, but those are less than a mm in length and are zero-force-insertion, so they don't require another step after the pick-and-place process.
I'm looking into alternatives. Some of them have SMD leads but anchor their frame to the PCB, like this one:
http://il.farnell.com/amphenol-fci/87583-2010blf/usb-2-0-type-a-receptacle-smt/dp/1314363
Can those be placed by a pick-and-place machine, or do they have to be snapped in manually? I assume they require manual soldering if you want those anchors to properly bond with the PCB, but can the initial placement be done with a machine?
Offline richardlawson1489
    • PCB Assembly
« Reply #6 on: March 15, 2017, 10:16:10 am »
I think the standard name is 4 pin socket.
