Author Topic: Laboratory oven -> Reflow oven?  (Read 8334 times)
Offline JaspaJamiTopic starter
    • Susijarvi
« on: May 17, 2018, 04:57:58 pm »
I have one Heraeus T5028 laboratory oven at warehouse without any use. Last time it was used as a egg incubator (this picture is not from my oven, but its same).
http://www.handelskontor-freitag.de/Verkauft/Heraeus-Waermeschrank-ST-5028-250-C-Heissluft-Sterilisator.html
Its quite big from inside, about 29 liters, and its no powerfull at all with about 800w.
But its quite nice looking, its very well insulated already. There is small latch top of the oven that can be opened.
What do you think? Can this be reused as a reflow oven? Is glass door how handy, this doesn't have that. For sure this need new heating elements.
Offline Pinkus
Re: Laboratory oven -> Reflow oven?
« Reply #1 on: May 17, 2018, 05:28:43 pm »
A glass window is a must in my opinion as different PCBs need a different profile and you need to check the PCB / soldering during the reflow phase. Especially with prototypes this is very helpful. Of course you can work without a window but you will miss it.
Also 29 liters volume is quite large - maybe too large to run a standard temperature profile.
« Last Edit: May 17, 2018, 05:32:03 pm by Pinkus »
Offline wraper
  • Country: lv
« Reply #2 on: May 17, 2018, 05:41:42 pm »
Won't work. Too large volume, too little power. It should have like 8 times more power to do the job.
    • Susijarvi
« Reply #3 on: May 17, 2018, 05:44:24 pm »
Why, if i have power to compensate that?
Of course it easier to stay in 1 phase, 16A, 230VAC. But i have 3 phase, 16A, 400VAC at lab (and if needed even more, because i dont have yet cables to coming lab and i have 3x35A fuses to house).
But yes, i agree, it is kind a large. But another oven + insulation is quite costly. Mostly im thinking of that window. I havent checked if its easy to make window to this oven (there is also models with window).
    • Susijarvi
« Reply #4 on: May 17, 2018, 05:45:38 pm »
Idea was to but totally new heating elements. I can easily but at least 3500w. If needed, with 3 phase much more.
Offline Richard Crowley
  • KJ7YLK
« Reply #5 on: May 17, 2018, 05:49:58 pm »
Isn't it also an issue with the thermal inertia of a large oven?
You can't control the fast temperature profile on the typical curve with a big oven like that.
Offline ElektroQuark
    • ElektroQuark
« Reply #6 on: May 17, 2018, 06:32:06 pm »
That oven is sloooooow. It has to much thermal inertia.
Home little ovens are slow too (take a look at my Youtube channel where I test one that finally gets modified).
Offline wraper
  • Country: lv
« Reply #7 on: May 17, 2018, 06:39:04 pm »
Thermal insulation is an enemy in this case. What you want is oven that heats up very fast and cools down fast as well.
    • Susijarvi
« Reply #8 on: May 17, 2018, 06:49:48 pm »
I did check them. Well i dont speak spanish but final modification was to add more power, those quartz heaters. Same idea was for me.
So idea was, is it possible or wise to modify this oven to reflow oven. Better reflective insulation to inside, maybe 3500w of quartz tubes for heating, aluminium/copper plate for the pcb:s
Offline jmelson
« Reply #9 on: May 17, 2018, 06:52:35 pm »
The only way to use this is to preheat the oven, and then slide each board in for a set time, and remove.
That doesn't allow you to do the ramp - hold at 180 C - ramp - hold at 240 C (or whatever) - cool
profile.  But, lots of people have reported pretty good results with kitchen pans on a hotplate, so it likely will work once you find the right combination of temperature and time.
You will have to come up with some scheme to place the board in a hot oven and then remove the board without jostling it too much, while the solder is liquid.
I cool the boards on the oven rack until it is down to around 100 C before removing from the oven.  My toaster oven heats and cools the boards a lot faster that your lab oven could, by IR radiation.
Jon
    • Susijarvi
« Reply #10 on: May 17, 2018, 07:03:31 pm »
Cooling down fast can be a problem. But i don't exactly understand why this would be so much slower to heat up? If i use similar heaters but more power to compensate that volume. And most likely stronger insulation.
    • Susijarvi
« Reply #11 on: May 17, 2018, 07:06:29 pm »
I think that even if i dont use this i have to make a test :D Install 3500/3600w of heating power and then measure how fast it can heat up.
Offline wraper
  • Country: lv
« Reply #12 on: May 17, 2018, 07:36:18 pm »
And where the heat goes away except opening the door in a right moment. It simpler to build an oven from a ground up rather that modifying this thing to work decently.
    • Susijarvi
« Reply #13 on: May 17, 2018, 07:44:22 pm »
For cooling down door opening can be automated also.
Offline wraper
  • Country: lv
« Reply #14 on: May 17, 2018, 07:46:41 pm »
First of all, it's not a right way to do the thing. Secondly, you'll end up attaching a rocket engine to this poor oven in effort making it do the task.
    • Susijarvi
« Reply #15 on: May 17, 2018, 07:57:48 pm »
i believe that its not maybe good idea to use this. But i think i can anyway test (even just for the curiosity) what kind of heating ramp i can achieve. Only parts that i need for that what i dont allready have are those quartz heating tubes. And most likely i need them anyway in another oven.
Oven most likely have to order from outside of Finland. Those ovens are not very popular here and very hard to find.
Offline ar__systems
« Reply #16 on: May 18, 2018, 12:05:14 pm »
Please don't use quartz heating tube. They are the worst. They heat via IR, leading to very uneven temperatures on the PCB.
    • Susijarvi
« Reply #17 on: May 18, 2018, 01:03:01 pm »
When then i have misunderstand. What kind of heaters you recommend?
EDIT: reason why i thought quartz would be ok was this one i think
"Type of element - the elements should ideally be quick to heat up and cool down. Resistive heating elements are extremely slow to heat up and cool down, and make it difficult to follow a reflow profile. Infrared elements are usually a poor choice because they heat up dark components before lighter or shiny ones. Commercial ovens use infrared elements, but only to heat the air which is then blown onto the boards. The compromise is to use quartz infrared elements which emit less IR. They are typically shielded with a perforated steel sheet which limits direct radiation. Also, Controleo3 will limit how much the top element is used to further reduce uneven heating."
http://www.whizoo.com/reflowoven
« Last Edit: May 18, 2018, 01:24:47 pm by JaspaJami »
    • ElektroQuark
« Reply #18 on: May 18, 2018, 03:07:04 pm »
I used common halogen lamps.
Offline wraper
  • Country: lv
« Reply #19 on: May 18, 2018, 03:42:29 pm »
Please tell me which heating elements are not resistive. Like inductive or which don't use electricity?
    • Susijarvi
« Reply #20 on: May 18, 2018, 03:49:05 pm »
Thats not my text :) Putting fire under the oven?
But i think its quite clear what kind of heating elements that text is meaning by that.
Offline luiHS
« Reply #21 on: May 19, 2018, 03:08:33 am »
A sterilization furnace like that has no control to apply a welding curve, nor fans to maintain precise control of temperature.
I would not use it to solder electronic components. In addition, today you have the T962 Chinese ovens, which are very economical and are made expressly for soldering electronic circuits.  I have a T962A and T962C, and I am very happy, they work very well, I also had the smallest model that I sold to buy the biggest ones.
« Last Edit: May 19, 2018, 03:11:51 am by luiHS »
    • Susijarvi
« Reply #22 on: May 19, 2018, 11:48:06 am »
For sure, but question was that could this be modified to that use.
Thanks, have to check more of those. If the really work price is not so bad
« Last Edit: May 19, 2018, 11:51:11 am by JaspaJami »
Offline SMdude
« Reply #23 on: May 19, 2018, 12:01:24 pm »
I have a T962A and it works quite well for what I do with it.
Do some research, there are some modifications and modified firmware for them, which after that has been done work well.
To modify the oven you already have, you would be better off just starting from scratch and making your own.
Keep it for drying moisture from boards and components.
The following users thanked this post: JaspaJami
    • Susijarvi
« Reply #24 on: May 19, 2018, 12:20:21 pm »
Thats maybe best one :)
Thanks for the help for everyone. Where i can find info of those different models of those T-9xxx ovens? And what modifications are recommended
EDIT: seems that here is quite good info about T-962A oven: https://esden.net/2017/11/27/upgrading-a-t962a-reflow-oven/
EDIT2: https://github.com/UnifiedEngineering/T-962-improvements
« Last Edit: May 19, 2018, 12:43:11 pm by JaspaJami »
