Author Topic: Low pressure / temp plastic molding  (Read 9189 times)
Offline DTJTopic starter
« on: January 19, 2017, 03:06:43 am »
I keep coming back to looking at low pressure desktop plastic injection molding systems for electronics.
There's systems like Macromelt that are used to over-mold low MP plastic onto PCBs and wire assemblies, stuff like this:
https://www.google.com.au/search?q=macromelt&safe=off&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiCjqStm83RAhXKKZQKHV61AsoQ_AUICCgB&biw=1920&bih=939
This is a quick overview of the process:
http://www.loctite.co.uk/uke/content_data/230400_macromelt_molding_EN_FINAL.pdf
There are parts available on eBay/Aliexpress for building your own bench-top molding unit as well as fully assembled units for around  Australian$1000.
The more commercial machines are more costly.
Has anyone here actually used this stuff?
I'm thinking of using it to over mold a PCB that's connected to the end of a cable and is used submerged in water as a sensor.  They'd be made in batches of 20 or so every few months.
Will it seal and will it last?
Offline technotronix
    • PCB Assembly
Re: Low pressure / temp plastic molding
« Reply #1 on: January 19, 2017, 05:18:36 am »
I don't have much experience with this parts, but I think It provides superior sealing.
Offline mrpackethead
  • D Size Cell
« Reply #2 on: January 19, 2017, 05:22:08 am »
I have used it extensively. And continue to use it extensively..
If you are doing anythign bigger than a few grams of plastic then you will need to have a serious machine. those benchtop machines just will end up being fustrating for you.
The stuff also shrinks after it cools, so you really need to consider htat.
I
The following users thanked this post: DTJ
Offline dimbmw
« Reply #3 on: January 19, 2017, 10:55:11 am »
There is no good adhesion between the cable and the material unfortunately, so it will not work.
  • D Size Cell
« Reply #4 on: January 19, 2017, 06:02:21 pm »
Macromelt was used to protect components used on the tools at deep water horizon. Some 5000' under water.   With the right design you can absolutely acehive a very good seal.
Offline dimbmw
« Reply #5 on: January 19, 2017, 07:14:53 pm »
I own a low pressure molding machine , and i asked this specific question to the machine's manufacturer. Their reply was discouraging - there is no good enough adhesion between the material and the cable's sheath. The water tightness should be ensured by something else. I guess that is what you are reffering as a "right design". But if you know how to do it by low pressure molding only - I am all ears, please educate me.
  • D Size Cell
« Reply #6 on: January 19, 2017, 07:28:00 pm »
Which machine do you have.. We have two, a optimel 2000, and a frakenstein that was made by converting a Boy 25 injection moulder..  Seriously the frankenstein works so much better particullary with larger shots..
What material are you using?   We typically use OM648 and recently TC50.
You have to design the die set so when the macromelt cools it shrinks onto the cable.  The shrink for 648 is around 1.5%   It shrinks on more that tight enough.     If you are really concerned there are 'primers' that you can apply as well..   ( Chemlok 485 with Curative 44 from Lord )
Offline dimbmw
« Reply #7 on: January 19, 2017, 08:16:17 pm »
We have one of the lpms's machines. Not sure about the resin, some of the henkel's technomelt resins. We are only overmolding USBs with it.
The shrinking idea does not look promising. It may be tight enough when there is no pressure (drop of water etc), but to withstand , let's say, 10 bars (100 m under water) is a different story.
« Reply #8 on: January 20, 2017, 12:51:39 am »
Thanks for all the replies guys. From what you've said it looks like it could work well though I might need more than a entry level or prototype machine as the injected volume is reasonably large at 16cc.
That probably means the set up cost would be out of my reach. Looks like I'll stick with potting in epoxy for now. I might keep an eye on ebay / gumtree. There was a small system for sale in Victoria / NSW a few months back for what seemed a reasonable price but it looks like it sold.
Again - thanks for the replies it's really useful to hear from folk who have worked with this stuff.
  • D Size Cell
« Reply #9 on: January 20, 2017, 08:24:34 am »
Its works at 5000'.  the equipment that was used on Deep Water Horizon was protected used macromelt.   Its all in your design.    I use it on parts that are 2-3m submerged and some have been running for 2 years without issue. I've got thousands of cable assemblys that are made with 648 and they lie around in the weather..
It works for us.
  • D Size Cell
« Reply #10 on: January 20, 2017, 08:33:01 am »
The biggest issue you have to overcome is being able to get enough material into the die set quick enough so that it does'tn start to harden before you've got it filled..    We have water heating in our die set, so its at about 70C, which really helps.   I've also got what can only been described as 'redicouly' large gates..   I'm pushing two cavitys of 54cm each.
At 16cc you might just get away with it.
Probalby painful but we can offer a overmoulding service out of New Zealand if its of interest to you.   (http://synapco.co.nz/low-pressure-moulding/ )
« Last Edit: January 20, 2017, 06:26:01 pm by mrpackethead »
Offline janekm
« Reply #11 on: January 20, 2017, 11:05:40 am »
I'm curious what search terms you used to find that? I haven't been able to find those parts (at least not within China) and I can't quite figure out why, you'd think it'd be a common enough thing (but I could get a second hand 15T vertical injection molding machine for around $1000... tempting but it would take up quite some space!).
  • D Size Cell
« Reply #12 on: January 20, 2017, 06:28:16 pm »
You need to add a bit to it to make it useable to be an overmoulding machine.. You need a melt tank and a pump to pump the molten plastic but its a very doable project.  Its what the guys did here..   a boy 25 conversion.
« Reply #13 on: January 21, 2017, 04:49:15 am »
Probably painful but we can offer a overmoulding service out of New Zealand if its of interest to you.   (http://synapco.co.nz/low-pressure-moulding/ )
Thanks but probably not viable as each unit has about 6kg of bulky cabling associated with it. Interesting website.
  • D Size Cell
« Reply #14 on: January 21, 2017, 05:10:21 am »
There is a crowd in Melbourne... i just cant' remember the name at the moment.
« Reply #15 on: January 21, 2017, 05:14:05 am »
I've found a variety of heating bands on eBay,
http://www.ebay.com.au/sch/i.html?_odkw=plastic+molding+machine&_sac=1&_osacat=170769&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xplastic+injection+machine.TRS0&_nkw=plastic+injection+machine&_sacat=170769
On Aliexpress I found a number of small desktop machines that looked like a drill press arrangement. They had a melt tank in the centre, pneumatic cylinder at the top and the mold at the bottom. I've spend some time looking and cannot find them again. Some of them had temp controllers, some didn't. Aliexpress is frustrating!
They were like this:
http://www.techkits.com/
There is a highly recommended (by others) book on how to DIY a machine by a guy called Vince Gingery.
http://gingerybooks.com/
Other interesting links:
http://www.scorchworks.com/Injection_molding/injection_molding.html
http://benchtopmold.com/index.php
http://makezine.com/projects/make-41-tinkering-toys/diy-injection-molding/
http://rick.sparber.org/Articles/gpi.pdf
I think DIY is do-able but keeping quality up might be an issue.
The following users thanked this post: Kean
« Reply #16 on: January 21, 2017, 05:15:29 am »
Tarapath?
www.lowpressuremoulding.com.au
Offline Kean
    • Kean Electronics
« Reply #17 on: January 21, 2017, 05:29:26 am »
And if in Sydney, I believe Clarke & Severn Electronics can also help with cable overmouding
http://www.clarke.com.au/cable_assembly.html
I've bought parts and equipment from them, but not used their cable services
  • D Size Cell
« Reply #18 on: January 21, 2017, 05:47:07 am »
Tarapath?
Yup thats the guys..     WHat i like about synapco is that they are actuyally really plastics guys.  And they really understand plastics. Rather than a cable /. electronics place that has added it as an extra.   It seems simple ( and it is ) untill you want to do somethign a bit out there.
« Reply #19 on: January 21, 2017, 08:54:34 am »
Yes I think production tools is Tarapath's core business.
Offline richardlawson1489
    • PCB Assembly
« Reply #20 on: January 21, 2017, 01:14:28 pm »
Which machine are you using currently? Are you thinking to get new updated machine?
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #21 on: January 21, 2017, 08:49:58 pm »
Bear in mind that Ebay doesn't show search results for items not shown as shipping to your country - some sellers who will ship overseas set this as default but say in their listings they will ship international if you contact them. This seems particularly common for larger items from the USA.
This site is a useful way of finding these international listings : http://www.geo-ship.com/
Day Job: Mostly LEDs
Offline Niklas
« Reply #22 on: January 22, 2017, 01:30:10 am »
Penetration of water through plastics could be an issue long term, especially for low power analog electronics like sensors.
Select a wire insulation material with good adhesion to Macromelt.
Avoid overmolding of connectors. You will be surprised how good penetration the molten plastic has, even inside crimped terminals.
Do not assume that the overmolding will provide a firm mechanical support if used above 70'C. There is a reason why the name ends with -melt.
Check chemical compatibility if the overmolded sensor is going to be submerged into other liquids than water.
The following users thanked this post: Kean, DTJ
  • D Size Cell
« Reply #23 on: January 22, 2017, 08:23:33 pm »
- I've had Macromelt underwater for more than 24 months continuous.. ( at about 2meters ) and as yet it has not failed.   I wont' say it wont', but i'd be quite suprized.
-Overmoulding connectors is quite doable provided you do it properly and DESIGN for it.    Please see example above.
-  The plastic is a polyamide.  It has good chemical resistance to most common things, other than acids which will eat it.
Offline Niklas
« Reply #24 on: January 23, 2017, 06:58:23 am »
It all depends on the application, but sensors are typically low power and their output signal can be affected by currents in the microamps range. For instance moisture acting as a resistor in parallel with an NTC or a capacitive sensor. We are currently working on a new project where a high performance engineering plastics is considered as an option for the housing material instead of stainless steel. One of the main concerns is the long term reliability due to water absorption and permeability. Expected service lifetime of the product is more than 10 years, submerged into a water based liquid, operating between -40'C and +85'C, 24/7.
Not all PCB connectors, actually very few, are made for either potting or overmolding. Take a standard wire-to-board connector with a pin header inserted into a connector housing with crimped terminals, horizontal assembly with complete overmolding/potting. You will then have 3 entry points: where the wire enters, through the hole for the latch and where the pin is inserted. The result is, most likely, a connector where even the volume between the pin and the terminal is filled with potting/overmolding material. There is also another possible entry point for liquid intrusion, and that is where the wires from the connector exits the overmolding. If the adhesion between overmolding material and the wire jacket is not complete, also considering thermal expansion and possible annealing, then capillary force can cause a leakage.
Take the same kind of connector, but with vertical assembly and only the pin header overmolded to a point well above the plastic part that holds the pins together. Here you need excellent adhesion to the metal pins to avoid leakage due to capillary force. If the connector is shrouded, then the adhesion demand also applies to the plastic material. As we are talking about a complete overmolding, we can assume no pumping effect from an enclosed gas volume (ideal gas law).
Our customers have a long list of chemicals that our product should withstand. Even if the product is used with a waterbased liquid, it should still withstand some abuse by a clumpsy end user, without any major impact. It all depends on the application, but it is very easy to just focus on the main purpose and to forget about the small details.
