Author Topic: Manual solder paste printer.  (Read 1586 times)
Offline hugeoneTopic starter
« on: April 17, 2018, 11:56:15 pm »
Hi.
I want to buy solder paste printer from China (probably via aliexpress) . Which one would you recommend?
Thank you
Offline l0wside
Re: Manual solder paste printer.
« Reply #1 on: April 18, 2018, 07:36:35 am »
You have two options:
* Buy a printer for framed stencils. Pro: printer is cheaper. Con: stencils are effectively only available from China, framed stencils are more expensive than unframed, shipping cost might be higher than for unframed due to size and weight.
* Buy a printer for unframed stencils. Pro: stencils available from virtually any supplier in the world (including China). Con: printer is typically more expensive.
You might want to look for a used printer, they typically do not wear off.
The following users thanked this post: hugeone
« Reply #2 on: April 18, 2018, 09:36:52 am »
I personally prefer the framed ones. Less work and you do not purchase then to often :) as they last for a while.
Actually I asked if someone has something to recommend as the quality of the Chinese products is a bit random :)
Offline girts
  • Country: lv
« Reply #3 on: April 18, 2018, 09:15:51 pm »
+ a lot of storage space necessary.
Why not to prefer unframed stencils if you are looking for manual printer anyway? Like these -
http://www.spide-smt.nl/products.html
