Ahmed i would recomend you look at international equipment exhibitions,
Nepconevery yhear in Anaheim in California
Produhere are other exhibitions You could attend to meet equipment manufacturers.
I would like to give you some brand names and You can invetigte their offering.
Laufer , Burkle multilayer presses( Laufer i think are a superior process.
Plutiech, Excellon, Klingelnberg drilling routing machines ( Klingelnberg are probably the better choice)
Resco, Schmid... wet process equipment,,etchers developers washing and scrubbing machines Resco offer a broad range but i think Shcmid are a better process machine
Multiline multilayerregisstration and tooling plate system.
OCR UV exposure machines
Yous hould also look into direct laser maging equipment ( no need for film photo tools) There is a German manufacturer who supply direct laser imaging technology a great solution for less than volume production setup.
Do You know how many square meters of PCB laminate you will be processing during a year?
You will also have to establish chemocal processes: tin plating, gold plating and copper plating along with hole wall activation process.
There are a number of chemical suppliers. Check out German com[any Atotech who offer paladium hole wall activation process along with copper plating process.
You will need additional mechanoical processes such as edge polishing machines Radol comes to mind.
I hope this helps You on your way. The above information is about ten years old, some of those names may now be defunct.
Good luck.
