Thanks...
..indeed, we are using the Seaward ClareHal 104 production tester to do earth bonding, hipot, and output power measurements. The product costs £6k and we need another one but cannot afford it.
So, we are currently using the Seaward ClareHal 104 end-of-line electrical tester...we need another, but the "104" is way too expensive and massively over-spec'd for our purpose....there dont seem to be any with our lesser requirements..do you know of any ?
We need Hipot to 3750ac rms.
The products are simple non-isolated offline 230vac led lamps. We need to hipot test from live/neutral to earth.
Seaward ClareHal 104 production electrical tester...
http://www.seaward.co.uk/products/industrial-electrical-safety-testing-measurement-equipment/safety-testing/hal-seriesThe Seaward ClareHal 104 product is massively over-spec'd for our products, because we only need to measure output power up to 200W, and the Seaward ClareHal 104 measures output power up to 5kW.
Also, we do not need a power factor measurement from the production tester.
Also, we only need to measure up to 1A of output current, and don’t need the measurement up to 20A as the Seaward ClareHal 104 provides.
May I ask do you know of a similar product, but suitably down-spec’d, for our humble purpose?
