Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Manufacturing & Assembly
Need help wit attaching the tip in a Weller DXV-80 through-hole desoldering tool
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Need help wit attaching the tip in a Weller DXV-80 through-hole desoldering tool (Read 1175 times)
rbm
Regular Contributor
Country:
on:
November 12, 2017, 09:11:01 pm »
I feel this is a silly-a$$ question. I bought a Weller WRS-1002 soldering workstation with a DXV-80 through-hole desoldering pencil amongst its attachments. The unit never came with a tip so I purchased one from Digikey. I've read the manual for how to attach the tip to the heating element, however I'm not sure that I've got it right. See the picture below:
https://photos.app.goo.gl/HV5msKJB42V34nv02
The tip is supposed to be inserted into the tool and turned 1/4 turn clockwise to secure it. I don't have the fancy Weller tool to do this so I used a 8mm combination wrench. The tip is secure but slightly off the centre line and part of the tip's base is visible. This is the best that I can do. The DXV-80 works but I'm not happy with the tip's position.
I've never owned one of these devices so I'm wondering if someone can please critique the way I've attached the tip. Is this normal?
Last Edit: November 13, 2017, 02:06:18 pm by rbm
Logged
- Robert
Neomys Sapiens
Super Contributor
Country:
Re: Need help wit attaching the tip in a Weller DXV-80 through-hole desoldering tool
Reply #1 on:
November 12, 2017, 10:34:45 pm »
Pigture missing!
There is a Weller tool called 'conus cleaner', which might solve the problem. Otherwise the handpiece might be damaged. Shouldn't look much different to the previous screwed ones, when inserted properly.
Last Edit: November 12, 2017, 10:37:22 pm by Neomys Sapiens
Logged
Mr. Scram
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
