Author Topic: Need SMD connector for through PCB connection - suggestions?  (Read 1745 times)
Offline YellofriendTopic starter
  • Country: hk
« on: February 20, 2018, 06:57:37 am »
I am looking for some suggestion how to connect something on the other side of a SMD PCB. Right now I use normal through hole connectors, but that requires handsoldering. Double side SMD isn't possible.
The only thing I am aware of that comes close are female SMD headers (see picture) that can be reflow soldered - and then you have a header on the other side that you can place through the PCB. Works perfectly. But I would prefer something that can be locked to prevent slip-off.
I need to connect 3 x 2pin wires. One pair is 3.7V power, two are connecting REED sensors.
Any ideas?
« Last Edit: February 20, 2018, 07:02:46 am by Yellofriend »
TVM802C - now with OpenPnP
T962A
Offline phil from seattle
Re: Need SMD connector for through PCB connection - suggestions?
« Reply #1 on: February 20, 2018, 07:16:32 am »
Not sure what you are asking for. If you mean SMD male pin headers, they exist.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: February 20, 2018, 09:14:40 am »
I don't get "locked", but do you mean alignment pegs or clips?
My first guess would be, browse Samtec catalog and see if there's any likely parts.  If they don't make anything quite right, there may be another company that does, but they'll be harder to search for, too...
Seven Transistor Labs, LLC
Offline donotdespisethesnake
  • Embedded stuff
« Reply #3 on: February 20, 2018, 07:23:05 pm »
I've never seen a connector that allows bottom entry and also latching, might be hard to find.
How would the latch work? It would need to come through holes in the PCB I guess. You could cut a slot for a flexi cable and run it to a locking connector on the top side. Depends on current requirement.
Bob
"All you said is just a bunch of opinions."
