Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Manufacturing & Assembly
Solder mask working too well? (on protoboards)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Solder mask working too well? (on protoboards) (Read 1879 times)
llkiwi2006
Regular Contributor
Country:
on:
September 14, 2018, 02:36:13 am »
I find it rather difficult to bridge solder between the holes on a protoboard, often I resort to using wire to connect pins up. I wonder if there's an easy solution or should I get protoboards without solder mask?
Logged
ogden
Super Contributor
Country:
Re: Solder mask working too well? (on protoboards)
Reply #1 on:
September 14, 2018, 04:02:22 am »
Brown (paper/bakelite) boards usually does not have mask, but does not have through-hole plating as well.
https://www.aliexpress.com/store/product/2Pcs-5-7cm-pcb-Prototype-Paper-Copper-PCB-5-7-Universal-Experiment-Matrix-Circuit-Board-5x7cm/1970323_32851437126.html
There are specialized prototyping boards with smaller clearances. One I just found for example:
https://www.aliexpress.com/store/product/Double-Side-Prototype-PCB-Universal-Breadboard-PCB-Test-Board-95mm-95mm/1829717_32705109940.html
Logged
llkiwi2006
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
