Hi Everybody,
Thank you for your attention and support on NeoDen Tech's products.
1.The NeoDen7 can handle 10mm height components directly without any custom work,you should do route planning work if the component over 10mm height,
Neoden7 z-axis max moving limit is 20mm.
2.NeoDen7 was using flying vision with fixed mirrors,which can support take photos after picking up components on the feeder immediately.
In this method,can help reduce the route distance and ensure fast CPH.
Any more questions,feel free contact to us via email,tks.
Best Regards,
Tonny-Neoden
