Hi TJ232,
That machine looks to be clean and well made.
We have a QiHe TVM920 currently and, aside from the 'normal Chinesiem complaints about poor software apps, it works well.
I believe you'll quickly tire of changing components in those 30 feeders [and even more quickly run out of feeders], and for this reason I'd certainly encourage you towards a machine with greater capacity. 30 feeders will get you 'most' of the distance [possibly - pending on your designs] but you need to appreciate that any component in a tape that is wider that 8mm [and there are plenty] will, at minimum, double your feeder slots requirement [one 12mm feeder takes up three 8mm slots, or two if it is placed in a group of other 12mm or 16mm feeders].
Check out the TVM920 if you haven't already [it has 56 8mm slots - 28 front & back, and capacity for 30 IC Tray components too], and let me know if I can assist with an intro to them.
Good luck - Peter
