Author Topic: New QiHe TVM925 Pick and Place  (Read 7044 times)
Offline CognitiveDevTopic starter
« on: January 30, 2018, 05:10:05 pm »
Hello,
I've been looking at purchasing a pick and place in the $10K range, and pretty much narrowed it down to the QiHe TVM920 or the Charmhigh CHMT560P4 after reading all the relevant threads on this forum (Thanks everyone!). However, while I was talking with the manufacturers last night, QiHe steered me toward the new TVM925, which they quoted at $6800usd.
https://qihesmt.en.alibaba.com/product/60472758393-804050637/Qihe_TVM925_Good_Sale_New_Manual_Led_SMT_Pick_and_Place_Machine_chip_mounter.html?spm=a2700.icbuShop.84.4.45961d6c31ypzI
This machine is replacing the TVM920, but has only 44 feeders. It has 6 total cameras, which I assume are for speeding up viewing /adjusting parts on all 4 heads. The max pcb size is 350mmx310mm. I'm not sure what the 6th camera is for- I see 4x upward facing for nozzles, 1x downfacing for pcb alignment, but it isn't clear what the other high resolution camera is used for.
Does anyone have any experience with this? I was really looking for a higher feeder count machine, and am therefore leaning toward the CHMT560P4, with 60 feeders, but the only think that turns me off is the built in screen. Though it is $1k less than the TVM925, so that is nice as well.
A little about our usage- we are looking to use this for prototypes in various quantities from 3 to 300. Our main BOM has 72 total parts on it, 66 of which come in 8mm tapes. Is it feasable to run several panels with one load, change the feeders, then run another session for the remainder of parts?
Thanks for your help,
Neill
Online mikeselectricstuff
    • Mike's Electric Stuff
Re: New QiHe TVM925 Pick and Place
« Reply #1 on: January 30, 2018, 05:25:03 pm »
I've seen one other 6-cam machine and the 6th is a larger field of view for large packages - QFP etc.
It used analogue HD cameras and presumably a capture card aimed at CCTV type applications, so not super high-res, hence needing different FOVs for larger parts.
The Chinese don't seem to have figured out that you can image larger parts in multiple passes, though the extra cam probably doesn't cost much more and should be faster. Can't see it on the 925 ad above, but I'd expect it to be at the back where trays would presumably go
Day Job: Mostly LEDs
Offline qihe_kim
« Reply #2 on: May 21, 2018, 07:26:48 am »
This is Kim from Qihe.
The TVM925 feeder’s count is 39 now because of the adjustment of the structure of the fuselage.
To make the fuselage more compact and save space.
It is convenient to transportation and handling.
But Our TVM925 can customize , like add feeder quantity .
About the high resolution camera is used for mounting IC components.
This is the video link of TVM925 :
http://www.qhsmt.com/shibinzhongxin/tvm925pnpmachinedispalyqihe.html
Offline harry4516
    • www.dj0abr.de
« Reply #3 on: May 27, 2018, 12:06:42 am »
could you please upload the video to YouTube. I cannot watch it on your web site, just a lot of chinese signs on a black background
And a question:
you claim for the TVM925 that it is usable for 0402. Is that really true ?
For the TVM802 you also specify 0402, but the 802 cannot handle 0402.
How can we trust that the TVM925 can do that?
« Last Edit: May 27, 2018, 12:13:21 am by harry4516 »
The following users thanked this post: ALEXRA
Offline qihe_kim
« Reply #4 on: June 20, 2018, 01:10:14 am »
And a question:
Sir,we have uploaded the video.You can watch it in this link:https://www.youtube.com/user/haowangjiao.
And when did you buy the TVM802?Our old model TVM802 can hardly handle 0402,but we did a lot of improvements and upgrades,and now our new model of TVM802 can handle 0402.Also you can watch the video of TVM802 in the link.
Offline ALEXRA
  • Country: in
« Reply #5 on: June 25, 2018, 07:53:02 am »
Hey  guys
I hope this video could be helpful   .
Beacuse LQFP100 placing looks really impressive !
seems much better than TVM920 model
Offline ALEXRA
  • Country: in
« Reply #6 on: June 25, 2018, 07:57:36 am »
share the youtube link  :-+
« Reply #7 on: June 25, 2018, 08:20:02 am »
Apart from the speed..
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #8 on: June 25, 2018, 09:44:25 am »
The camera is a little myopic.
Offline ALEXRA
  • Country: in
« Reply #9 on: June 26, 2018, 01:14:04 am »
1'10" the second chip is irregular placement  in IC tray.
Maybe the camera needs time to fine-tuning analyzing  correct angle .
Offline qihe_kim
« Reply #10 on: June 28, 2018, 07:28:18 am »
When we plcaed the first chip, we posted it step by step for better presentation. If customer keep the machine running continuously, the speed would be faster.And in the latest software,We have improved the camera recognition speed.We will show in the next update of the video.
Offline qihe_kim
« Reply #11 on: July 04, 2018, 12:42:42 am »
After update the software,we speed up the recognition speed.
Offline harry4516
    • www.dj0abr.de
« Reply #12 on: July 05, 2018, 12:12:22 am »
thank you for uploading your videos to YT.
When will you sell the TVM925, and will it be available via aliexpress ?
And where to get the feeders (whats the cost of the feeders) ?
« Last Edit: July 05, 2018, 12:18:25 am by harry4516 »
Offline qihe_kim
« Reply #13 on: July 05, 2018, 05:47:35 am »
We have been selling 925 for 6 months.And it will be available via aliexpress.You can click below link to buy it.And we also provide the feeders.You can consult our sales to buy the feeders.They can give you a detailed quotation.
925:
https://ru.aliexpress.com/item/TVM925-Automatic-Led-SMD-Mounter-LED-High-Speed-Pick-Place-Machine-SMT-Pick-and-Place-Machine/1000001627660.html?spm=a2g0v.search0104.3.52.49c35a1aJa279A&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10151_10065_10068_10344_10342_10325_10546_10343_10340_10548_10341_10696_10084_10083_10618_10307_10059_100031_524_10103_10624_10623_10622_10621_10620,searchweb201603_32,ppcSwitch_5&algo_expid=1f7906bf-31b1-4ec9-9c55-f999d9db14fd-8&algo_pvid=1f7906bf-31b1-4ec9-9c55-f999d9db14fd&priceBeautifyAB=0
Offline Marmes
« Reply #14 on: October 05, 2018, 05:34:51 pm »
Does it have conveyor option?
Offline Smallsmt
« Reply #15 on: October 05, 2018, 09:20:45 pm »
No it has no conveyor but if you need choose the QM41
Offline mrpackethead
  • D Size Cell
« Reply #16 on: October 06, 2018, 07:12:28 am »
you probably can save a stack of cash by shopping around on the feeders.   You can get 8mm CL feeders for around USD$60 or less, if you buy a machine full.
The ones i've bveen using work fine with a tvm920.
Offline steffenmauch
« Reply #17 on: April 24, 2019, 04:14:28 pm »
Does anyone has an user manual for the TVM925?
If yes could you attach it or send it to me via PN?
Thanks.
