Author Topic: Nippers / Cutters for FR4, for separating PCBA out of carrier frame?  (Read 2628 times)
Offline smoothVTerTopic starter
Hi Everyone!
I'm wondering if anybody has any suggestions on the best way to cut out a PCBA, or more specifically a rigid-flex PCBA, out of its retaining frame.  My PCBA has a very irregular shape with many radiused inside and outside corners, arcs, and small small rigid off-shoots connected to flex.   Imagine something like this, but with many more flex sections coming off into many more rigid sections:
There are mouse-bites on all over my PCBA outer edges, holding it to the frame, similar to the above photograph.    It is not possible to twist out all pieces of this PCBA by hand because it would rip and/or put stressed on the flex parts, some of which are only 2mm wide.   For the time being I've been using some Hakko  flush-cut pliers intended for copper wire, and that sort of does the job, but leaves a very rough edge and creates micro tears in the FR4.  It also wears the metal of the cutters fairly quickly.
The other consideration is that the space between the PCBA and carrier frame is 1/4" or so.  Any kind of hand cutters or nippers would need to fit in between this 1/4" gap, and be able to cut a straight line in the FR4.
Are there any standard tools for cutting out PCBAs from their carrier frames, other than the flush cutters I already described?   That can (a) withstand 1000's of cuts through FR4  (b)  leave a rather clean edge   (c)   not cost $10000?
« Last Edit: September 27, 2018, 04:17:23 pm by smoothVTer »
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: Nippers / Cutters for FR4, for separating PCBA out of carrier frame?
« Reply #1 on: September 27, 2018, 04:30:11 pm »
Add extra slots & mousebites to the waste so you can snap it off in sections.
You can also put snap-out tabs like this
https://youtu.be/kLKSon2GnY0?t=932
Day Job: Mostly LEDs
The following users thanked this post: Mr.B, Koen
« Reply #2 on: September 27, 2018, 04:31:53 pm »
Nice cutting board ( bamboo probably as it survives well, and is non static) and a Stanley knife along with a box of the blades. Otherwise you are into the realm of having bespoke punch and die sets where the appropriate points are the cutting edges, and it pops the whole thing out as a unit, after you place the full board into it and get the alignment pins you made as part of the frame right. Or how are you for a mini CNC mill and some small carbide milling cutters and a screaming speed spindle, along with a base board ( particle board like Masonite or chipboard) that has both a sacrificial aspect ( it handles the cut through part) while also having some polished die pins to hold the board in place while cutting.
« Reply #3 on: September 27, 2018, 04:33:07 pm »
There are also purpose made tools like these
https://www.somersetsolders.com/manual-pcb-depaneling-tools/p10
https://www.ebay.co.uk/i/252179964778?chn=ps&var=551916297452
Though these do need enough length of straight slot to get the head into, and enough component-free space at the sides of the slots
« Last Edit: September 27, 2018, 04:36:40 pm by mikeselectricstuff »
Offline electrolust
« Reply #4 on: October 01, 2018, 10:08:22 pm »
hakko makes some nice cutters, in various sizes. they do leave a "cut" edge, if you need a smooth "machined" edge you'll need to file it down afterwards.
Online langwadt
Offline Delia
  • Country: cn
« Reply #6 on: October 15, 2018, 12:37:44 pm »
The PCB factory did not make well about the outline.
Offline Mattylad
« Reply #7 on: October 18, 2018, 08:38:20 pm »
Just by the break off tabs, make the route path so that it nips into the border a little more so you have room for the cutters.
I.e turn 90 degrees outwards for about 3mm+
Matty
CID+
Offline kkritsilas
« Reply #8 on: October 21, 2018, 12:25:41 am »
We used to use a very small router bit with an automated router head when I was in manufacturing. During NPI (before board outline was completely settled and the automated router head was programmed), we used a Dremel with a small dismeter router bit, or a Dremel with a flex shaft and a cut off wheel, depending on board layout.
If possible, and if this under your control, try to use scoring vs. “Webs”. The scored boards always have a clean edge (if done properly) and never have the problem of the substrate delaminating if somebody tries to twist the cracker/carrier section off.
« Last Edit: October 25, 2018, 03:40:01 am by kkritsilas »
Offline Nusa
« Reply #9 on: October 21, 2018, 07:06:51 am »
I suspect a cheap wood chisel and a mallet on a wood surface would work fairly well.
