Author Topic: Pick & Place MachineTVM920  (Read 99238 times)
Offline ALEXRA
  • Country: in
Re: Pick & Place MachineTVM920
« Reply #550 on: June 25, 2018, 05:46:58 pm »
Finally found the TVM925 video!!
seems much better than TVM920 model
LQFP100 placing looks really impressive !
Offline ACE5582
« Reply #551 on: August 02, 2018, 12:51:49 am »
Has there been any more progress with the open-pnp project on the TVM920? Are users happy with the TVM920? I've been lurking on this forum in hopes of getting some good vibes before I pull the trigger on one of these. I was fairly optimistic until the last few posts and it seems things have died down on this? Is there a better machine out there for around the same price? I'm also looking at the TVM925. It looks like it has 6 heads instead of 4. Any help would be appreciated! BTW I currently have the Neoden TM-240A and have been limping along with it for a while with my projects.
Thanks in advance!
Online Kjelt
« Reply #552 on: August 02, 2018, 01:05:47 am »
It takes about 20 seconds to look at the ic before placing it, what is it doing all that time ?  :-//
Offline harry4516
    • www.dj0abr.de
« Reply #553 on: September 06, 2018, 09:22:08 am »
like with the TVM820 and others, the QiHE software has a serious problem with the camera. If I set vision to "accurate" (TVM820) then the adjustment takes a very long time, and is still not perfect. So I am using the quick-mode only, which is much faster and has almost the same accuracy as the accurate-mode.
Offline zszabo
  • Country: hu
« Reply #554 on: January 22, 2019, 09:03:17 am »
Hello,
Which version is Your software ?
THX.
Zoltan
Offline zszabo
  • Country: hu
« Reply #555 on: January 22, 2019, 09:04:35 am »
Hi again,
Where can be fount the new nozzle holder ?
THX.
Z.
Offline jmelson
« Reply #556 on: January 22, 2019, 10:12:16 am »
Well, the placement rate for the small passives was a LOT better than many of the other low-cost machines!  That was really nice to see!  The camera alignment cycle on the LQFP was pretty slow, however.  But, the placement looked really accurate.  Better than my mechanical alignment machine does them!
This shows some REAL promise.
Jon
