Author Topic: pre sensitized boards and Expose the board, to a white light. and other question  (Read 402 times)
Offline whitevamp
ok so i am looking at making my own boards and have been doing a lot of research on them, and i new about the standard way of exposure with UV light.
but then i found these boards that say they are new and require a
quote : Expose the board, held in the frame, to the light of a 100 watt white light bulb.
http://www.philmore-datak.com/datakpos.html
so my question is has any one tried these boards and if so are they any good?
see i plan on doing the transparency method as i have over 5000 sheets of tektronix transparency film, and thought what better use for it. trying save a few pennies here and there.
or is there  better less expensive way of doing this?
also i saw on http://www.instructables.com/id/Stop-using-Ferric-Chloride-etchant!--A-better-etc/
is this a good way to do this or should i just stick to FCE?
or is it better to just go the toner transfer method?
if so i hear everyone saying to use magazines, but my question is ho do you clean the preexisting ink in the magazine so you can print on it?
