Any Idea on why I should prefer Digikey over Aliexpress?
Digikey have built their business by only purchasing from 1st tier suppliers (normally direct from the manufacturer themselves).
The counterfeits are normally very good with their "remarking" but the differences can normally/often/sometimes be spotted under the microscope.
You can purchase both the OEM part from Digikey & the cheap parts from Aliexpress & have a good look yourself.
In this case there is a huge difference in price, however excess/no longer used 1st tier stock does turn up on Aliexpress. As a "rough rule" these "real OEM" parts are priced at somewhere between 50% & 70% of the volume OEM price. In these cases the vendor will normally state the actual manufacturer of the parts ie On Semi, Fairchild etc & you can ask (& often receive) for a copy of the invoice from the 1st tier supplier. Often these invoices are 3 to 10 years old which indicates how long these parts have been held in stock.
We are currently doing a stock take of our excess stock & will list volume numbers of micros such as some old ST6 micros, PIC16F72, PICF73 on Aliexpress shortly.
Our stores are however based in Australia
