It starts with design.
No matter how "good" a component is it will have poor reliability if run to hot or too near the abs max spec.
For me, electrolytic caps are possibly the obvious place that buyers like to play games, the good stuff is expensive and the poor stuff looks like the good stuff if you don't get it. I have a mental short list of the acceptable in a quality product, it features the usual half dozen or so suspects.
I would note that there is more to electrolytic caps then people often think, **READ** the datasheet carefully, ripple ratings vary with frequency, and remember that it is not just the fundamental, but also the harmonic currents, a properly applied 85 degree part can last longer then a poorly thought out application of a 105 degree unit.
Low ESR is NOT always a good thing, pick the part to have the appropriate characteristics for the job in hand, a 1000uF 40mR polymer elco on a big power plane can be trouble.
MLCCs vary far more then you would expect between manufacturers, especially in some of the high K ceramics, read the long form datasheet and pay attention to what happens as the package size drops (Also pay attention to the crack prevention guidelines).
Resistors are sometimes also a lot more complicated then you would think, thick film often has measurable excess noise and some linearity issues for example, if designing stuff where that matters specify the part and manufacturer, often it is a small number of parts in a much bigger BOM, but that set of 10 resistors being expensive thin film ones can lower distortion by a factor of 10.
Sand, not all versions of the 5532 (or any other chip) are created equal, take the time to qualify what you use.
MOSFETs, you can safely ignore the first page current rating on the datasheet, it is almost always fantasy, also the RDSon figure only applies at specified junction temperature and gate voltage, if you are lucky some work with a calculator and the graphs further into the datasheet will tell the real story. Be careful of substitutions here as well.
Board materials, not all FR4 is equal, mainly a high frequency thing, but the higher Tg boards have lower thermal expansion, Tg150 is not much more expensive then Tg130.
Design for test, zero ohm links between sections of power planes makes fault finding so much less annoying.
Basically it comes down to use suppliers (and supply chains) you are comfortable with, do not skip on the fine print in the datasheets, and be conservative.
Regards, Dan.
Regards, Dan.
