Author Topic: Sealant that sticks well to PVC cable insulation?  (Read 7713 times)
Online e100Topic starter
« on: April 01, 2018, 06:29:58 am »
I need to waterproof some outdoor sensor lead connections that have conventional PVC insulated copper wire.
Can anyone recommend a sealant that bonds strongly to the PVC insulation so that water cannot creep between the insulation and the sealant to form a leakage path.
PVC in the plumbing industry has a reputation for being non-stick unless you resort to solvent based adhesive/sealants that partly dissolve and bond with the PVC. Using something like a PVC gutter sealant somehow doesn't seem right. It also has a multi-day cure time and shrinks as the solvent evaporates.
Online mikeselectricstuff
    • Mike's Electric Stuff
Re: Sealant that sticks well to PVC cable insulation?
« Reply #1 on: April 01, 2018, 08:20:51 am »
Why not do it properly and use cable glands ?
Day Job: Mostly LEDs
« Reply #2 on: April 01, 2018, 08:50:23 am »
I have 4 float switches that are mounted close together. Each has 2 wires, so 8 in total. The tails are short so I don't have much scope for spreading them out onto a panel with 8 cable glands.
« Last Edit: April 01, 2018, 08:59:59 am by e100 »
Online tggzzz
« Reply #3 on: April 01, 2018, 08:59:00 am »
PVC cables are flexible. Many sealants become less flexible over time. If the sealant is less flexible and the cables do flex, then there may be a crack for water ingress.
Depending on how the water could arrive at the relevant points, it may be possible to discourage water travelling along the cable by putting a "u-bend" immediately before the relevant point.
Offline Electro Detective
« Reply #5 on: April 01, 2018, 09:00:34 am »
It's a good way to go if the compressed rubber thingie inside the gland doesn't turn to goo or dry up and blow away in an outdoors scenario
Old school non acetic silicone anyone?   ;D
« Reply #6 on: April 01, 2018, 09:02:06 am »
Well they are specifically designed for the purpose, so unlikely ( unless it's some cheap crap from Aliexpress..)
« Reply #7 on: April 01, 2018, 09:10:30 am »
TwoHungLow Gland Corp. sell them on Ebay too   ;D
« Reply #8 on: April 01, 2018, 09:28:58 am »
For small cables you can get glands down to about M6 in stainless
http://www.newark.com/lapp-kabel/52001860/cable-gland-mini-brass-m6-3mm/dp/98K9727
and M8 in nylon, though these are quite hard to get hold of
http://www.avc-corp.com.tw/english/3_Catalogue%20Pages/210-1010.pdf
« Reply #9 on: April 01, 2018, 10:10:00 am »
The float switch wires are 1.4mm in diameter which makes it hard to find a suitable multi-hole cable gland.
It's equally difficult to find suitable silicone rubber tubing that could be used as a sleeve to bring the diameter of each wire up to something that is more commonly available.
Offline tautech
« Reply #10 on: April 01, 2018, 10:26:00 am »
What's wrong with heat shrink ?  :-//
As for sealants...RTV and preclean with suitable solvents and lightly roughen with fine wet&dry paper.
Avid Rabid Hobbyist
Offline BravoV
  • +++ ATH1
« Reply #11 on: April 01, 2018, 10:30:15 am »
Heat shrink tube + hot glue cut into small pieces well placed evenly "inside" the tube, once heated, the heat shrink tube will squeeze out the melted glue, and shape and grip the inner PVC cable as whole.
Just an idea.
« Reply #12 on: April 01, 2018, 10:35:52 am »
You can buy this - it's called "adhesive lined heatshrink"
But all that gets you is a bigger diameter cable you still need to seal to the panel
Offline BravoV
  • +++ ATH1
« Reply #13 on: April 01, 2018, 10:40:10 am »
Thats the idea, and then wrapped at the panel side with hot glue and make sort of seamless join to the cable part.
Another interesting long term (years) characteristic of this hot snot glue exposed for "years" in salt water and sun, from another forum fellow (Rufus), read carefully this particular -> POST and subsequently the -> Proofs, quite interesting and convincing imo.  :-+
Offline SMdude
« Reply #14 on: April 01, 2018, 11:17:06 am »
Probably the best way to go is the glue lined heatshrink.
Another personal favorite is sikaflex 227 over the soldered joint and a bit to each side, then heatshrink over the lot. It's nicest when the sikaflex spooges out from either end of the heatshrink. Wear gloves, it's messy!
Tip for sikaflex: When not in use, store it in the freezer. It will then last for years in storage.
« Reply #15 on: April 01, 2018, 11:29:16 am »
Interesting posts.
It would also appear that hot melt adhesive heat shrink is used for insulating mains voltage cable splices.
Is it 'regular' hot melt glue, or special in some way, I have no idea?
« Reply #16 on: April 01, 2018, 11:42:06 am »
Here's the datasheet.
http://aus.sika.com/dms/getredirect.get/au01.webdms.sika.com/107
Like many manufacturers they manage to avoid saying what it actually sticks to other than saying 'plastics' which is meaningless given the huge diversity of plastic types.
« Reply #17 on: April 01, 2018, 11:49:38 am »
Liquid electrical tape as a seal also works, and sticks to PVC well as it is solvent based and chemically bonds to the PVC itself. The glue lined shrinks do work well, and you can use them as a cover for the join, followed by wrapping with regular 3M insulation tape and then overcoat with self amalgamating tape, then cover with more 3M insulation tape and a final coat of liquid tape to make a join that will still be there when the rest of the cable has disappeared from UV exposure, and the copper inside has corroded away.
Offline DerekG
  • Country: nf
« Reply #18 on: April 01, 2018, 12:21:29 pm »
OK, I can help you here.
We use this product to seal PVC pipes that pass through concrete & fibreglass pool walls. Never had a failure in 8 years of use & the pipes are either under suction or pressure. These pipes are permanently under water & subject to chlorinated water. Only comes in white. It is a hybrid polymer.
https://www.bunnings.com.au/selleys-480g-3-in-1-silicone-sealant_p1230061
And we use this product to seal glass into PVC window frames. It is a co-polymer & would appear to have a higher volatile solvent content in it than the one mentioned above. The solvent smell is quite strong until it sets:
https://www.bunnings.com.au/selleys-260g-all-clear-multipurpose-sealant_p1210350
Even after category 3 cyclones, the sealant is still holding on strong to both the glass & the PVC frames. Note these are smallish windows. Once you get into larger windows, the frames must be either aluminium, steel or wood laminates to comply with category 5 cyclone requirements.
If you are still worried, you could de-grease/clean the PVC cable first with some ?isopropyl alcohol before applying the sealant.
I also sat between Elvis & Bigfoot on the UFO.
« Reply #19 on: April 01, 2018, 01:56:11 pm »
Interesting, the "Selleys 3 in 1" says for "most plastics (not for polyethylene, polypropylene or teflon)", which is a lot more specific than most other manufacturers are prepared to say about their products.
The related (perhaps the same) "Selleys roof and gutter" also specifically list PVC roofing.
Based on the sketchy information on the Selleys web site these appear to be 'modified silicone' adhesives rather than polyurethane based.
The safety data sheet says that there are no hazardous ingredients which is highly unusual for any adhesive. Any volatile solvents or would be automatically listed as hazardous.
The Selleys All Clear is a different beast altogether. It is solvent based and takes a long time to fully cure and shrinks as the solvent evaporates. The SDS says that it contains up to 30% cyclohexane and heptane, so you would expect the long term shrinkage to be similar.
« Reply #20 on: April 01, 2018, 02:03:46 pm »
I tried liquid electrical tape and was not impressed. It really didn't have much sticking power. The cured film could simply be rolled off using my fingers. Perhaps it only works reliably if it has mechanical protection?
Offline reboots
    • http://reboots.g-cipher.net
« Reply #21 on: April 02, 2018, 07:10:44 pm »
The compression sealing element in those glands is just a neoprene plug with molded-in holes. So replace the plug with a blank piece of neoprene or similar rubber stock of the same length and diameter, from McMaster-Carr (US) or your friendly local materials supplier, and drill or pierce your own holes specific to your needs.
« Reply #22 on: April 02, 2018, 10:32:20 pm »
I'm told they are easier to drill if you put them in the  freezer for a while first.
Offline DerekG
  • Country: nf
« Reply #23 on: April 02, 2018, 10:45:46 pm »
Don't forget there are plenty of panel grommets & cord anchors available. These give a professional look. In the past, we have simply dribbled some contact adhesive (made by UHU or Selleys) around the cable/grommet/box panel on the inside of the box. This anchors the cable & does make the cable entry waterproof & it is very quick to do which is important when production volumes go up. The solvent in the contact adhesive slightly "melts" the surface of the PVC box enclosure, so you know the grip is strong.
https://www.digikey.com.au/products/en/cables-wires-management/bushings-grommets/491?k=cable%20grommets
« Reply #24 on: April 03, 2018, 02:39:52 am »
I did some tests and it didn't stick strongly to soft PVC cable jacketing. The harder PVC used for electrical boxes or PVC pipes didn't work much better.
It's strange stuff to apply as it has the consistency of lumpy toothpaste. Once cured it's like a semi-hard silicone rubber.
