So, now that I find (to my horror) that VPC is stopping production of their UV-exposed Quick-Mark technology, and a quick scan of the net turned up nothing similar, I have to figure out what to do!
So, this stuff I've been using for about 20 years does this:
I make a negative image on silver litho film with my laser photoplotter. I contact print that negative onto the Quick-Mark film and separate that film from the dye layer. This gives me a positive image sheet in the color of my choice, with the words reading right and the image on the BACK of the film. I then laminate that to their base sheet, stick that down to the aluminum panel and cut out holes for switches and connectors. Kind of a tricky process, but makes a NICE-looking, very durable panel.
Does anybody know of any other outfit that has something that you can do yourself? The idea is a self-stick material with the printed label laminated BEHIND the front sheet.
What I think I could probably do is take VPC's digital film over to FedEx Office and have them print on that with a color laser printer, and then do as always with the laminating.
One plus with this process is I can have multiple colors on the panel. A possible problem is FedEx may not want me putting some untrusted material into their printers.
Thanks in advance for any suggestions!
Jon
