Never seen this on other's products, but I've been doing exactly this; funny to see I'm not the only one coming up with the idea. The reasoning is, there often are pins that end up non-connected. By removing the pad, this space is usable for signal or power routing, or improved ground plane connection (relevant on 2-layer design). Adding the silkscreen should reduce the risk of penetration of soldermask due to vibration scrubbing off the mask slowly; the pins could have sharp edges. I have done this on a QFN as well, although I wouldn't recommend it since this may cause too much standoff and hinder proper soldering of the other pins. On QFP, I see no negative side effects; although, for high reliability in high-vibration environment, I wouldn't trust the insulation, even when reinforced with the silk screen.
