FYI, the customary language is probably confusing:
"Silver solder" or "hard solder" refers to a medium-melting braze alloy, based on silver (usually combined with copper, zinc and others). Melting points are in the red-hot range.
"Silver bearing solder" refers to a tin and/or lead based alloy, which contains silver to increase strength. (Because it's stronger, it might also be considered "hard" in comparison to other soft solders, so beware of this too.)
For electrical soldering, you'll be doing the latter, soft soldering, because of the required low melting point. To stick to silver metal, absolutely any alloy is fine. The silver metal will be dissolved somewhat (let it soak a while, and even if you started with plain Sn60 or whatever alloy, you'll now have silver-bearing
), but that's only a problem on plated layers. You'd have to wash it with a lot of solder to dissolve much of a bulk item.
