Author Topic: SmallSMT PNP adventure, learning and documenting  (Read 6272 times)
Offline revenue_controls
Re: SmallSMT PNP adventure, learning and documenting
« Reply #25 on: April 21, 2019, 06:25:49 am »
Continuing...
I received the stand via UPS in three boxes/foam rapping. All were in good condition and wrapped well. I started to video the unboxing and assembly but it got tedious very quickly. I will include some completed pictures.
As I removed the items from the packaging, I was impressed by the top quality. The extruded rails and the assembly hardware are all heavy duty. Not stamped steel, but cast aluminum right angle mounting brackets with M8 1.25 bolts. The nut rail inserts were also of high quality and have a spring loaded ball bearing on them which keeps them in position during assembly!
The included manual has pictures but can use more assembly notes. I did not know at the time that by popping off some tabs on the angle brackets they can be used in different assembly connections. I emailed Michael and he filled me in quickly. Also note the rail nuts can be popped into the rail at any point in the rail, they do not need to be slid in from the end of the rail.
Assembly takes several hours, there are a lot of bolts. I left most of them loose until finishing to allow for repositioning. When done, I checked every bolt and really cranked down on it. I known around here for stripping bolts on a regular basis, but I did not strip any of these bolts and nuts! These are not cheep crap. I'm glad to pay for something of quality, Its paying for disappointing crap that will give the manufacture a bad reputation.
However, I did make some improvements to the caster mounting, adjustable leveling feet and the parts reel holders (Will upload pictures soon).
Modification to the caster mounting. I added a bushing to the bolt because the hole in the caster is too big.
Added lock nuts to the leveling feet
Added some rubber washers to the reel mounting rods
a good tool to have; the metal part of a file folder hanger
This stand is very nice, top quality and very strong. Nice job SmallSMT!
« Last Edit: April 21, 2019, 08:18:15 am by revenue_controls »
« Reply #26 on: April 21, 2019, 06:56:52 am »
pictures...
« Reply #27 on: April 21, 2019, 06:57:55 am »
pictures...
« Reply #28 on: April 21, 2019, 06:58:54 am »
pics
« Reply #29 on: April 21, 2019, 06:59:35 am »
pics
« Reply #30 on: April 21, 2019, 07:01:12 am »
pics
Online IconicPCB
« Reply #31 on: April 21, 2019, 08:38:02 pm »
Seems like Mr Packethead is looking to place an order. Ibet he is waiting for the forthcoming exhibition to purchase the show machine at a decent discount.
The following users thanked this post: mrpackethead
« Reply #32 on: April 21, 2019, 09:16:32 pm »
Michael, send my commission check to my same shipping address!
Offline Kjelt
« Reply #33 on: April 21, 2019, 10:22:00 pm »
Looks good :)
Those cost € 0.18 vs €0,12 without the ball, but they work nice , used them also on my CNC build  ;)
https://www.smt-montagetechnik.de/produkte/44.htm
Offline mrpackethead
« Reply #34 on: April 22, 2019, 05:32:33 am »
You'll probably need to ask Sunny for that.
Offline Smallsmt
« Reply #35 on: April 22, 2019, 05:42:50 am »
Good news you assembled the kit well.
It's a big puzzle.
« Reply #36 on: April 22, 2019, 06:51:22 am »
Thanks, it was fun.
I Added platform to the bottom.
Is one needed on the top for the machine?
Or does it mount directly to the top rails?
« Reply #37 on: April 23, 2019, 08:47:40 am »
When is the PNP machine arriving?
« Reply #38 on: April 23, 2019, 09:15:51 am »
Sunny confirmed the CL feeders order quantities this morning, so I hope they will ship it soon. However I hope they are not rushing it out because of my posts.  I would not want them to jeopardize the build quality. This is week 8, you can send a man to the moon in 8 weeks!
« Last Edit: April 23, 2019, 09:17:37 am by revenue_controls »
Online IconicPCB
« Reply #39 on: April 23, 2019, 11:24:40 am »
Looking at the images i guess the platform on the side of the frame is support for reels on the push feeder side.
Seems like You have a variety of push feeder widths in Your machine setup.
How did You decide on the mix of feeder widths?
« Reply #40 on: April 23, 2019, 12:11:09 pm »
The spacing of the push feeder reel separators in the pictures is completely random at this point. However, to determine the feeder widths, you need to know what size (height mostly) parts the machine is capable of dispensing, how many slots the machine has, how many feeders the machine has and of each type, the availability of packaging for each part in your BOM, and your BOM.
« Reply #41 on: April 23, 2019, 12:18:25 pm »
There is a lot of trading off, and different ways to get it configured. I think (hope) what I ordered will be close to what I need. It will depend a lot on the machines actual performance. I may end up getting different feeders to dial in the best feeder configuration for my BOM.
Offline Smallsmt
« Reply #42 on: April 23, 2019, 10:22:01 pm »
Thanks, it was fun.
There is no plate needed on top of table the machine screws on the rails.
Offline Smallsmt
« Reply #43 on: April 23, 2019, 10:26:45 pm »
I think within the next 7 days it need one week shipping time.
Offline SWR
  • Without engineering science is just philosophy.
« Reply #44 on: April 25, 2019, 07:21:02 am »
My VP-2500DP WNE just arrived today, so now it's time for unboxing and final assembly.
The box was very solid and there doesn't seem to be any transportation damage by the first inspection.
It's got 79 reels, 18 strips, 7 sticks, 68 alu tray squares and 300x300mm area that is shared between PCB and plastic component trays. I'm looking forward to trying it out and reading about your experiences with the VP machines.
You should never go down on equipment!
« Reply #45 on: April 25, 2019, 07:59:45 am »
I'm looking forward to it as well. I think they just shipped my machine. How long did you wait for your machine?
Offline SWR
« Reply #46 on: April 25, 2019, 05:55:35 pm »
About 10 days shipping. :-+
This is my fist P&P so I have a rather long list of tasks ahead of me before I'm ready to roll with it:
-Assembling the optional extras (two extra feeder drivers, vibration feeder, strip feeder, large tray and dispenser)
-Installing moisture trap
-Connecting air compressor
-Wall mounting above table to allow room for reels and reduce table shake
-Design and 3D print individual reel holders
    The 3 trays included with the machine with 28 7" reel slots have the following issues:
    -Takes up more room (height) if you want to change reels individually
    -Have higher drag resistance than reels rotating on a center hub (not sure if this is a problem?)
-Installing software
-Interfacing to DesignSpark PCB
-Structuring P&P friendly component library
-Building P&P friendly component library
-Finishing schematic & layout
-Ordering components
-Ordering PCB with stencil
-Test run with double side tape
« Reply #47 on: April 25, 2019, 07:43:59 pm »
WTF, I have been waiting 9 weeks. Are you saying 10 days of actual shipping time or total of 10 days from ordering the machine?
Offline Smallsmt
« Reply #48 on: April 26, 2019, 04:42:01 am »
Steve,
the reason was part shortage first and we are sorry for the delay.
Our production time is normally 5 to 6 weeeks.
Thew DP machine is simpler to produce need 4 weeks only.
Your machine has free dispenser unit installed I hope this could be nice for you.
Best regards
Michael
Offline SWR
« Reply #49 on: April 26, 2019, 05:06:01 am »
It was 10 days of actual shipping excluding the time to build the machine.
