I've made some boards with a lot of JST and pin headers/connectors and other elements that I want to glue down tight to the board as they will be used quite a lot. What sort of glue would be best for this?
I know some sort of epoxy would work well, but they are quite expensive, especially the named brands from the US when over here in the UK. Maybe some off-brand names that work just as well?
I've tried UV cured adhesive and it's garbage.. It sets far too soft and leaves a Vicks Vaporub smelling greasy residue.. or at least the chineasium one I've just tried.
Thanks.
