Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Manufacturing & Assembly
Test rig - original vendor?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Test rig - original vendor? (Read 1263 times)
Martin F
Regular Contributor
Country:
on:
January 06, 2019, 11:52:02 am »
Hi all,
We're looking to purchase a test rig, along the lines of below:
https://buy.macaos.com/products/test-jig-120x80mm-board
We've seen many use similar test rigs online, but we've been unable to find the original manufacturer of this. While we could buy it via the above link, we're hoping to find the original manufacturer as we'll need quite a few of these.
Any of you have an idea of where this might come from or be available?
If you know similar test rigs at lower cost, we'd also be interested.
Best,
Martin
Logged
beanflying
Super Contributor
Country:
Toys so very many Toys.
Re: Test rig - original vendor?
Reply #1 on:
January 06, 2019, 12:22:05 pm »
Find a local CNC capable plastic fabricator and get them made to suit your design or needs. Best if you can in that instance YOU do a lot of the design as you know what tolerances are needed for the pogo pins and test fixtures.
The clamps are nothing special (modified toggle clamp with maybe a sleeve bearing on the shaft for accuracy) and the frame is a simple Laser or CNC routing job. Base frame could be good quality Ply (what I think the link shows for the base frame) or Plastics.
If you buy 10 from my I bid 749 euros each and I will
have a European holiday
personally deliver them
edit added link for the clamp
https://www.banggood.com/GH305C-Toggle-Clamp-BRH-500-Lbs-32mm-Plunger-227Kg-Holding-Capacity-Push-Pull-p-1392937.html?gmcCountry=AU¤cy=AUD&createTmp=1&utm_source=googleshopping&utm_medium=cpc_elc&utm_content=frank&utm_campaign=pla-brand-elc2-au-pc-0517&gclid=Cj0KCQiA68bhBRCKARIsABYUGic52zcUCRISZyeZtuJfCdo2h5jSDfAlsPiAZ9qvOwXtIUBdC1Q1QGAaAtAEEALw_wcB&cur_warehouse=CN
Last Edit: January 06, 2019, 12:26:38 pm by beanflying
Logged
Gribo
Frequent Contributor
Country:
Reply #2 on:
January 07, 2019, 03:05:39 pm »
What is the purpose of your jig? There are many test jig vendors out there, with price range of few 100Euro to tens of thousands Euro.
Logged
I am available for freelance work.
SWR
Regular Contributor
Country:
Without engineering science is just philosophy.
Reply #3 on:
January 09, 2019, 08:49:04 pm »
I bought this one to play around with:
https://www.aliexpress.com/item/PCBA-Test-Tooling-PCB-Test-Rack-Universal-Embryo-Rack-Universal-Test-Rack-Empty-Rack-Jig/32919411165.html?spm=a2g0s.9042311.0.0.27424c4dyaOobv
It's propably not the original vendor but it's quite cheap and they do custom sizes.
I'm planning to 3D print the needle and pressure plates and build DPS5005 PSUs, DMMs, load resistors and J-link programmers into the bottom tray.
Logged
You should never go down on equipment!
Martin F
Regular Contributor
Country:
Reply #4 on:
January 10, 2019, 07:49:52 am »
Thanks all!
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
