Author Topic: Trying to track down SONY robot programming manual  (Read 1313 times)
Offline HHaaseTopic starter
« on: January 11, 2019, 02:45:25 pm »
I stumbled on a good deal for a local machine, a Sony 'Cast-U' gantry robot with an Apollo Seiko solder controller.   Everything seems to be working just fine, but I don't have any documentation on the SONY side of things.
Any chance you guys may have worked with one of these in the past, or know where I can find programming instructions?
Worst case is I'll convert it to MACH3 at some point,   but I've got more important places to spend the money if I can put that off for a while.
-Hans
Offline nsrmagazin
  • Country: ru
Re: Trying to track down SONY robot programming manual
« Reply #1 on: January 11, 2019, 04:44:44 pm »
Where did you stumble on it? The seller should have the documentation.
Hi all!
If you like the post, please press "thanks".
« Reply #2 on: January 11, 2019, 05:09:16 pm »
Seller had no documentation, I did ask.
Sony shut down their industrial robot division over a decade ago,  so can't go that route either.
Offline nsrmagazin
  • Country: ru
« Reply #3 on: January 11, 2019, 09:32:13 pm »
Even if its 10 years ago, they still might have some support for it. Such things are expensive and should be with a long term support. You can ask them, however its not certain that they will want to help you.
Your other option is experience, if I were you I'd look up "robot programming forum" in google.com(NOT bing.com).
Hi all!
« Reply #4 on: January 14, 2019, 04:40:31 pm »
Sony shut down their whole Manufacturing Systems Division about 15 years ago,  and the distributors I spoke with also said there is no source for support.
All I've found so far is a couple youtube videos.
Not a huge deal though.   I may just get a Mach3 controller and convert it to a newer system anyway.   All the hardware is just fine, and everything works, just a matter of how to program.
Offline nsrmagazin
  • Country: ru
« Reply #5 on: January 15, 2019, 07:13:24 am »
The programming is done in "Assembler" or "C".
Here is a good link:
https://www.robot-forum.com/robotforum/
Hi all!
« Reply #6 on: January 15, 2019, 05:06:51 pm »
It actually uses a teaching pendant, but there are a few critical steps that aren't clear in how they operate.
The biggest ones are how to save a program into one of the memory locations.
I'll check that forum out, see if somebody there has used them in the past.
