Hi Macck,
i know the quadra well, both the meccanical and the laser one, not the evo.
Meccanical use meccanical grippers for centering and works down to 0603. Laser works down to 0402.
Laser it have cameras and cognex laser sensor for part centering.
Meccanical have support for rs232 vga jpg camera instead of the slow align spring based align jig.
Just connect it on COM and the software recognize it.
Meccanical do 2k7 cph an laser 3k6 ipc.
The difference between evo and laser/meccanical is that evo run linux with modern interface, the other use dos software.
For the dos software you definitly need a small introduction course, 2 day, in order to be productive. There are a lot of external
dos software for feeder diagnosis, laser sensor diagnosis, .... that are absolutly needed to know and don't are intuitive at all.
Further for meccanical Feeders you need to manage the feeder database at file level in order to be productive.
Meccanical Feeders costs 150 Euro and Laser/Evo cost 300 Euro, always 10cm width, for 8mm there can be 8 slots inside 10cm.
If using this machine in production 8-12h/(working day), every year there is a necessary replacement kit, 96Euro. This includes ventury ejectors stages,
cables that are subject to moves and other small items.
As it's a dos machine, install dos ethernet card and working is easier, evo is annother story as linux have usb support, but i don't know that machine and i don't
know if users have root access or what access levels there have at all.
