Author Topic: Using KICAD....Help  (Read 2432 times)
Offline Big DuckTopic starter
Using KICAD....Help
« on: April 17, 2018, 10:44:13 pm »
I am brand new to Kicad. I used the footprint editor to create a footprint for a Bourns PTL series linear fader. I can not figure out how to put it in a library so I can use it on a layout of a board that I want to make.  The whole "library" thing is quite puzzling.
PLEASE HELP!!!
Offline hermit
Re: Using KICAD....Help
« Reply #1 on: April 18, 2018, 04:19:42 pm »
The Kicad forum has a good FAQ on the library issues.
https://forum.kicad.info/t/faq-index-thread/8890
Offline ElektroQuark
    • ElektroQuark
« Reply #2 on: April 19, 2018, 07:34:43 pm »
Do you read Spanish?
If so, here you have the best KiCad guide that has been ever written (in any languages):
http://elektroquark.com/forokicad/index.php?topic=4.0
Offline fourtytwo42
  • Interested in all things green/ECO NOT political
« Reply #3 on: April 19, 2018, 07:58:31 pm »
PLEASE HELP!!!
Don't worry, your not alone, every single CAD system out there has a confusing library system and they all take time to learn, unfortunatly unlike the drawing system itself there are no intuative standards. I am pretty stupid but got there in the end :)
Offline iabarry
« Reply #4 on: May 10, 2018, 02:59:50 am »
Sorry to be a month late with this...
In the FootPrintEditor:  File:  Set Active Library
Make the foot print you  want.
Edit the FootPrint Properties (menu item with a gear over and IC near the center top). Mostly this is verify the name.
In the graphical menu at the top, select the 2nd item:  Save Footprint in Active Lib
Offline Doctorandus_P
« Reply #5 on: May 26, 2018, 03:34:50 am »
Addition:
This is for the current KiCad V4.0.7.
In the soon to be released KiCad V5 the whole library system has been overhauled.
Offline Gibson486
« Reply #6 on: May 30, 2018, 01:41:13 pm »
Addition:
LOL...they are going to overhaul it again? I hope the changes give altium a run for its money (not that it does not already).
Offline Bassman59
  • Yes, I do this for a living
« Reply #7 on: May 30, 2018, 06:52:36 pm »
Addition:
The schematic libraries, which have remained pretty much the same for several years now, are being revamped to work more like the PCB libraries.
Offline Gibson486
« Reply #8 on: May 31, 2018, 12:21:00 pm »
if I remember correctly, the schematic library makes a file and one big file. So if you have resistors library, all resistors go in one big file? if that is what they are changing, I am all for it. Also, they should change how schematics reference things. Instead, it should just make a local copy. Nothing sucks more than having someone change something in a shared library and having it resonate to an older design.
