Author Topic: What about power resistors from ebay?  (Read 2251 times)
Offline 001Topic starter
  • Country: aq
« on: November 19, 2017, 05:21:20 pm »
Hi!
Is aluminium housed power resistors from ebay usable?
Offline ChrisLX200
Re: What about power resistors from ebay?
« Reply #1 on: November 19, 2017, 05:41:33 pm »
Usable for what? - fishing weights?  Need to be a bit more specific, but I can say you need a big extra heatsink for a resistor like the one pictured if you hope to get anywhere near the rated 100w.
Offline HighVoltage
« Reply #2 on: November 19, 2017, 06:05:13 pm »
Usually when I need to use 50W or a 100W power resistor, I also need reliability.
So, I am using good quality power resistors only from VISHAY, OMITE or DALE.
Offline ChrisLX200
« Reply #3 on: November 19, 2017, 06:19:33 pm »
This is a 50w (claimed) 1Ohm resistor, it's sandwiched between the two heatsinks shown. If I put 10w into it the temperature rises to 65degC with convection cooling, I have yet to test using a fan how much power it can dissipate with forced air cooling. Arguably these heatsinks are far too small for the power rating.
« Last Edit: November 19, 2017, 06:23:10 pm by ChrisLX200 »
The following users thanked this post: 001
  • Country: aq
« Reply #4 on: November 19, 2017, 06:51:41 pm »
Thanx! Best answer  :-+
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #5 on: November 19, 2017, 07:14:44 pm »
My guess is at least some of these have this inside:
Offline DerekG
  • Country: nf
« Reply #6 on: November 20, 2017, 02:22:47 am »
Ask for the spec sheet & then test it to the max if you need the entire power dissipation rating.
Run it for hours on end to check that it survives.
If you only want to run it at half of the power rating, then it will probably be fine. Again test it for many hours/days just to make sure.
I also sat between Elvis & Bigfoot on the UFO.
