Author Topic: What is this Socket ?  (Read 2916 times)
Offline y33tTopic starter
« on: April 18, 2017, 04:00:26 am »
It's a USB 3.0 micro variant socket but have no idea what it is. Two pins are longer than others free from plastic shielding. I need to order some of them and female version of these.
What is this socket ?
Offline Monkeh
Re: What is this Socket ?
« Reply #1 on: April 18, 2017, 04:09:12 am »
It's a plug, it's not 3.0, and at first glance it looks normal.. Photo's too out of focus to see the pins.
The following users thanked this post: ar__systems
« Reply #2 on: April 18, 2017, 02:55:23 pm »
Here is a better version. It might be a plug but the end cable goes to a USB 3.0 port.
« Last Edit: April 18, 2017, 04:25:58 pm by y33t »
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
« Reply #3 on: April 18, 2017, 03:13:57 pm »
Might be a standard USB Mini A plug. Else it has to be proprietory.
He’s like a trained ape. Without the training.
Offline wraper
  • Country: lv
« Reply #4 on: April 18, 2017, 03:17:21 pm »
What do you mean by that? Type A plug has the same dimensions for both USB 2.0 and 3.0 and are compatible, 3.0 plug/socket has a few additional pins.
How many pins connector on the photo do have?
« Last Edit: April 18, 2017, 03:19:38 pm by wraper »
« Reply #5 on: April 18, 2017, 04:27:04 pm »
Please see the image. I count 7 pins and the shield/ground.
Online krho
  • Country: si
« Reply #6 on: April 18, 2017, 05:32:45 pm »
I'm sorry, but I'm holding somthing like that in front of me and I know that's micro USB up to 2.0.
Online Ian.M
« Reply #7 on: April 18, 2017, 05:43:34 pm »
So its proprietary - too many pins and too wide for its thickness to be USB Micro-B.
What device does it normally plug into?
Offline Monkeh
« Reply #8 on: April 18, 2017, 08:12:44 pm »
None of which we can see.
It's definitely not a standard micro, it's also most likely not USB 3.
It's not a standard part, you'll likely not be able to just order it. Look up whatever it came from.
Offline Neilm
« Reply #9 on: April 19, 2017, 05:45:12 pm »
It looks similar to the one on my Sony camera - I know that is not a standard USB
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
« Reply #10 on: April 24, 2017, 07:50:17 pm »
Which camera is that precisely and what is the end cable look like ?
