Author Topic: 3458A ADC section innards  (Read 2928 times)
Offline diegogmxTopic starter
« on: January 12, 2019, 06:22:29 am »
I've been checking out the schematics of HPs 3458A multimeter today, it really caught my interest since it is a device designed in the end of the 80s (before i was born actually), yet the accuracy it reaches is remarkable even by today standards.
when checking out the adc section i must say (with some embarrassment) that i got quite lost.
first of all U180 the ADC or at least part of it seems to be a custom part, so i really don't know what it does with a decent level of certainty, i would appreciate if someone could illuminate mi a little there
i've read in a cern paper that this meter as well as other super accurate ones use dual slope adcs, which if im not wrong in this case it's not made from a single ic, the integrator seems to be external and at least to me surprisingly convoluted, so does the comparator, and there is a slope amp that looks just like a precision rectifier, not yet sure of it's purpose
in short Help :P
i would really appreciate if someone could guide me through this a bit
*cant attach the schematics, the file is too big
yet it can be downloaded from here
https://www.schematicsunlimited.com/h/hp-agilent/hp-3458-8-digit-multimeter-schematic-and-clip
Offline Micke
Re: 3458A ADC section innards
« Reply #1 on: January 12, 2019, 07:42:49 am »
The 3458A design is discussed in great detail in the April 1989 HP Journal  :)
http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1989-04.pdf
Hope it helps!
The following users thanked this post: diegogmx
Offline Kleinstein
« Reply #2 on: January 12, 2019, 09:24:14 am »
U180 combines a very good quality resistor array and matched analog switches (presumably JFET) and switch drivers.
The ADC is a classical multi-slope design. So in principle not that special, though running relatively fast, e.g. with a rather fast integrator.
The other point seems to be a good implementation: e.g. very good resistors inside U180 and little parasitic effects.
While the principle circuit is relatively easy to reproduce (with modern parts), the implementation with little extra effects form something like capacitive coupling or supply coupling is still difficult today. So getting the same linearity is the difficult part, while the noise level should be relatively easy.
« Reply #3 on: January 12, 2019, 06:13:46 pm »
Hope it helps!
i'll take a look at it
yes, the linearity for what i've read is about 0.1ppm which is really insane, for what i've seen analog devices highest resolution adc today has about 0.5ppm peak in full scale
Online tggzzz
« Reply #4 on: January 12, 2019, 06:28:48 pm »
The Art of Electronics III, section 13.8.6 "Designs by the masters: Agilent’s world-class “multislope” converters"...
With these analog-switch applications in mind, we’re in good shape to understand the “multislope” techniques used in instruments like the Keysight 34420 7 1/2-digit and 3458A 8 1/2-digit multimeters.
Offline dacman
« Reply #5 on: January 25, 2019, 02:51:21 am »
U180 used to be a fairly flat IC with pins on all four sides.  It is now a daughterboard and I believe the designation is A13.
Online TheSteve
  • Living the Dream
« Reply #6 on: January 25, 2019, 03:29:04 am »
U180 has never changed. It is the gate array ASIC that was changed and now uses a daughterboard.
VE7FM
