Author Topic: Absorption plate set for gamma radiation  (Read 1538 times)
Offline PhysikfanTopic starter
« on: July 10, 2018, 10:47:38 am »
On Ebay I found an absorption plate set for gamma radiation:
« Last Edit: July 10, 2018, 10:52:09 am by Physikfan »
Offline babysitter
  • pushing silicon at work
Re: Absorption plate set for gamma radiation
« Reply #1 on: July 10, 2018, 12:40:48 pm »
Genosse Abschirmski! :)
I'm not a feature, I'm a bug! ARC DG3HDA
Offline CopperCone
  • *knock knock*
« Reply #2 on: July 11, 2018, 01:02:19 am »
The finish on that lead plate looks trashy. Give it a gentle sanding over and a coat of polyurathane.
Offline InductorbackEMF
  • Repair/Rebuilding.
« Reply #3 on: September 18, 2018, 06:57:19 am »
Is that plate just made of lead? If so with the amount of lead i have i could build two boxs haha.
Want a cup of TEA? (just one more meter please..)
Alex.
Offline Kleinstein
« Reply #4 on: September 19, 2018, 02:46:17 pm »
The plated have a defined thickness. So one could add a thin layer of varnish, but should not remove much oxide.
The plated are made from different materials: lead, aluminum, copper and iron.  The list of contents (first picture) gives a good list.
This set looks like made for schools / education, so nothing extra accurate.
