Help! I am becoming a voltnut. Two meter pics are attached. The first one is with the AD5791 programmed for 10 volts and the second one is one bump up (19 microvolts more). So all is working well. The drift is wobbling around very little (a few microvolts).
The meter is new (to me) so I have to learn some things. I found LabView stuff for mean, standard deviation and intend to pursue that route. So far, have not got any of that working. Also, not able to read the cal ram data. The meter came with a USB to GPIB adapter, so perhaps just a matter of learning how to use it (having a driver issue).
I also cobbled up a 10 kohm (within 1 ohm) resistor and now will try a 4 wire measurement. Might as well be an ohmnut too.
