Hi,Mr.Kleinstein and Mr. Mickle T.,
Thanks a lot!
I found that some of the INL is coming from my voltage source for testing ,the DIY LTZ 7-10v source. The former might be not so stable and I reassembly a new one yestoday. The other contribution might be the 0.022uf cap parallel on the DMM when using with the resistor string, as I had took them to filter some noise. And also for the single voltage capturing, I using 20 point avarage instead of just 1 estimation. And also some modification before like adding the decoupling cap on each OPs, it likely helps to the final result. The update INL curve looks much better than before, which I had never imaged. But there still have 0.3-0.4ppm error in the middle of positive range and it is more like the performance of others 6581.
I will try to add some load to U206. I am also considering about the leakage of the MUX when in high positive voltage input , but can not prove it. This might lead to the INL error over the 0.1ppm limit, right? I suppose that the fresh MUX have few leakage and lead to the ideal INL curve as the datasheet. When suffered by the surge in some condition and the protection circuit malfunctioned at that moment, the leakage of the switch became extreme large and contributed to the INL of positive range finally.
Attached FYI.
Best Regards,
szszjdb
