Author Topic: arithmetic mean value vs TRMS AC+DC  (Read 2167 times)
Offline Ig_sherwoodTopic starter
« on: November 07, 2016, 09:41:31 pm »
Maybe this question will be dumb ,but im just an hobbyst in electronic field  :-//
So i want to ask you today if it's still good to buy an multimeter without TRMS ,only arithmetic mean value ???
There is a good guy ,which want to sell me an gossen metrawatt 23s and i don't know if this deal worth or not.
Offline helius
Re: arithmetic mean value vs TRMS AC+DC
« Reply #1 on: November 07, 2016, 10:52:12 pm »
It only depends if you care about the accuracy of AC measurements on non-sinusoidal signals (such as square waves or PWM signals). Some high-priced meters do not have TRMS, such as Metrahit 27: some users simply do not need it. But if you will test things like triac light dimmers, TRMS is useful to have.
The following users thanked this post: Ig_sherwood
Online 2N3055
  • Country: hr
« Reply #2 on: November 07, 2016, 11:41:39 pm »
Also any work on audio needs TRMS... and about 100 kHz of bandwidth...
Offline David Hess
  • DavidH
« Reply #3 on: November 08, 2016, 12:02:58 am »
Unless you already have an application which needs RMS measurements, I would not worry about it.
I actually prefer to disable RMS on my RMS meters if possible because it slows down the settling time a lot with lower signal levels; in some cases it can take 10s of seconds to settle.  I only use it when absolutely necessary which is rare.
« Reply #4 on: November 08, 2016, 12:11:22 am »
Online 2N3055
  • Country: hr
« Reply #5 on: November 08, 2016, 07:13:04 am »
Normal multimeters will not work on 13 MHz in AC mode... Most are few kHz and good ones are few 100 kHz.. For 13 MHz you'll need an oscilloscope or RF multimeter..
In practice that means you need oscilloscope...
