Author Topic: Bottled! 10K Resistor  (Read 7209 times)
Offline zhtoorTopic starter
  • Country: pk
« on: May 07, 2018, 07:32:30 pm »
« Last Edit: May 22, 2018, 01:02:01 am by EEVblog »
Offline BNElecEng
Re: Bottled! 10K Resistor
« Reply #1 on: May 07, 2018, 07:49:52 pm »
What is your end goal with this?
Offline kj7e
  • Damon Stewart
« Reply #2 on: May 07, 2018, 07:53:50 pm »
This one $26 resistor will far outperform the the 10 parts in parallel your proposing;
https://www.digikey.com/product-detail/en/vishay-foil-resistors-division-of-vishay-precision-group/Y145310K0000V9L/Y1453-10KA-ND/2609894
Edit: I just pulled one out and put it on my 34465A.  When trying to obtain precision, the least expensive option will never yield the best results.
« Last Edit: May 07, 2018, 08:23:21 pm by kj7e »
The following users thanked this post: eurofox, zhtoor
Offline eurofox
    • Music
« Reply #3 on: May 07, 2018, 08:07:52 pm »
I got one like that, build it into an hermetic enclosure with 4 decent binding post and 2 packet of silica gel.
This way I build a quite cheap 10K reference.
eurofox
eurofox
The following users thanked this post: kj7e
Offline pigrew
« Reply #4 on: May 07, 2018, 08:19:49 pm »
I like the idea of soaking the resistor in oil to help it maintain a constant temperature. You could add an RTD (Pt100?) in the bottle to get a better idea of the resistor's temperature. It'll certainly help with humidity, but my gut instinct is that it wouldn't help (much) with aging. You may be able to fix the TC by selecting components with complementary TC in some range.
The following users thanked this post: zhtoor
Offline rhb
« Reply #5 on: May 07, 2018, 10:43:42 pm »
The composite aging should be readily determinable by measuring the resistance and temperature during initial operation.  The aging curve is  almost certainly an exponential decline to a constant value.   This is based on basic mechanics of materials considerations, stress, strain and visco-plastic deformation.   That curve can be solved to ~1% for a period in the future equal to the length of time for which you have prior data.  If the part  changes by 40 ppm in a year,  with 6 months data one should be able to predict the change to under 1ppm over the course of the next 6 months.
The TC presents some interesting problems.  It would be nice to have histograms of the coefficients for a third order polynomial fit to a bunch of resistors and run some Monte Carlo simulations of the composite TC for various topologies.
Offline GigaJoe
« Reply #6 on: May 09, 2018, 01:53:28 am »
yeah, had play this way, relatively cheap resistors in par, seq but metal film only  .....
it doesn't has to be 100k  to make 10k, it can be 4.99 or 5.11. or better some variations where you can find it cheap
the most important are tempco, so ....
get as much as you can, resistors diff value ...
measure each one for tempco, it may be positive or negative even in one batch
calculate connection in sequence parallel , to compensate tempco and get in summary a close to target value but should be below it....
burn it at 150-170 C for a few days; that would be oxidation ageing process
construct it together
then adjust a final resistance value by altering a metal surface, increasing a resistance use a scalpel or something sharp , you may consider a high nominal in parallel,  if screw it up trow it and start again. then coating a few layers of conformal ....
then you can dump a final product in the bottle :)
that would be a week of fun and stable, low tempco product , with some patient and good source you may outperform $26 resistor :)
btw, 25ppm usually possible to find for .05-.1 ; 0.50 - kinda expensive to play with .. bought 5ppm for $.11
« Last Edit: May 09, 2018, 02:22:44 am by GigaJoe »
Offline RandallMcRee
« Reply #7 on: May 09, 2018, 04:34:20 am »
Lets just state the obvious: for over $100 time investment you may, perhaps, do better than buying a $26 resistor....
Offline eurofox
    • Music
« Reply #8 on: May 09, 2018, 04:42:48 am »
outperform $26 resistor  :wtf:
Resistance   10 kOhms
Tolerance   ±0.005%
Power (Watts)   0.6W
Composition   Metal Foil
Features   Moisture Resistant, Non-Inductive
Temperature Coefficient   ±0.2ppm/°C
Operating Temperature   -55°C ~ 125°C
And you need an instrument able to measure the resistance up to 0.005%
 :palm:
eurofox
Offline GigaJoe
« Reply #9 on: May 09, 2018, 05:04:56 pm »
eurofox, As  I said, it matter of source material and time spend, for tempco and value - how precisely you compensate and measure. and environment stable temperature and humidity, and equipment.   for example: HP3478A (5.5) pretty amazing in accuracy, for a last year 2 my units drift to 1 and 2 LSB. means it possible to measure .005%, consider to match with some reference ,  or use a bridge, if again, you have reference ....
Offline eurofox
    • Music
« Reply #10 on: May 09, 2018, 08:58:52 pm »
I never said that it is not possible but imagine checking a bunch of resistor the PPM + and PPM - and put them together the way they compensate each other and finally you need a "meter" that is calibrated and that is very precise. You stil need to solve the humidity influence.
I prefer to pay 27$, put it in an hermetical enclosure and know that I have a good reference.
eurofox
eurofox
Offline kj7e
  • Damon Stewart
« Reply #11 on: May 09, 2018, 09:00:32 pm »
hello friends,
something for your viewing pleasure.
best regards.
-zia
Your original idea was to just simply take 10, 100K parts and wire then in parallel then encase it in rosin, not to combing neg and pos TC parts to cancel out TC.
While you may be able to cancel out some or even most of the TC within a given window, you still end up a host of other issues.  Load life, self heating, aging rate which all lead to a drifty standard.  Now instead of one, you have many parts to account for and none will act or age exactly the same as the rest.
It would take a nice TEC box, at least one high end DMM (you will need more resolution and stability than a 3468 or 3478), and weeks of TC testing and component selection to save just a few bucks.  Not a very good trade off if your intent is to make a usable and stable reference vs academic.
« Last Edit: May 09, 2018, 09:11:23 pm by kj7e »
Online tszaboo
« Reply #12 on: May 09, 2018, 10:26:35 pm »
Resistance   10 kOhms
Tolerance   ±0.005%
Power (Watts)   0.6W
 :palm:
You aren't reading the datasheet right. For 10K, the tempco is "±0.2 ±0.6", AKA 0.8PPM/K. Welcome to the world of "bulshitting on the front page" by Vishay Precision group. Oh dont get me wrong this is still probably one of the best resistor money can buy.
The following users thanked this post: hwj-d
Offline kj7e
  • Damon Stewart
« Reply #13 on: May 09, 2018, 10:36:02 pm »
I wish I didn't see they had these in stock  :palm:;
https://www.digikey.com/product-detail/en/vishay-foil-resistors-division-of-vishay-precision-group/Y407810K0000V9L/804-1059-ND/4233065
Oh well, also picked up a Hammond 1594RABK copper lined RFI/EMI shielded heavy duty plastic case that will be perfect for this.
https://www.hammfg.com/electronics/small-case/plastic/1594r
I already have some Pomona 3770 posts.  It will give me something to play with over the weekend while I'm grounded.
Offline rhb
« Reply #14 on: May 09, 2018, 10:56:16 pm »
Did you go for the 50 or the 100 unit price break?
Offline CalMachine
  • Metrology Nut
« Reply #15 on: May 09, 2018, 11:06:16 pm »
Perhaps this is a good place for a sneak peek  :-/O :popcorn:
All your volts are belong to me
The following users thanked this post: Vgkid, kj7e
Offline Vgkid
« Reply #18 on: May 10, 2018, 12:44:55 am »
*snip*
fedex shipping around $40 (i think), make sense for a few nominal or group buy
You know that's a scam site right?
Prices looked a bit too low :(
Offline kj7e
  • Damon Stewart
« Reply #19 on: May 10, 2018, 01:43:26 am »
Offline CalMachine
  • Metrology Nut
« Reply #20 on: May 10, 2018, 02:36:25 am »
Secret magic sauce  \$\Omega\$
CalMachine: here is *the* BOX ! (with an SR104 in the bottom)
kj7e: what's in the box?
zhtoor: a bottle?
 :-DD
btw.
@CalMachine, a very nice looking ref. i can't really see, but is it 10K? *AND* those binding posts are $26 each.
best regards to all of you and keep em coming ....
-zia
Yes it is the 2nd 10k prototype!  Preliminary measurement logging is showing roughly -0.1 ppm/ºC TCR.
Offline GigaJoe
« Reply #21 on: May 10, 2018, 04:37:55 am »
Frankly , had no idea ...
But, google the thing found at least 4 websites with the same design , same resistors, same price as above  .... *&^$*&$ ...
HK inventory has 0 (NULL) such items, seems whatever you find it , it a scam,  or a pure luck of old stock, if it so ...
Offline kj7e
  • Damon Stewart
« Reply #22 on: May 10, 2018, 05:06:24 am »
Once I saw the price, I did some searching and found many references to fraud.  You cant even buy VHP's used off eBay from China for those prices.
Offline CalMachine
  • Metrology Nut
« Reply #23 on: May 10, 2018, 12:12:15 pm »
@CalMachine
don't you think that a pt100/thermister kelvin-sensed
(thermally bonded with main resistive element),
also in the box could be useful?
-0.1 ppm/degC tempco, could it be "compensated" with a copper wire?
(or a differential length on "secret magic sauce  \$\Omega\$")
best regards.
-zia
The current prototypes employ a 2 wire connection on the side of the box to a 10 kOhm NTC thermistor.
Offline HighVoltage
« Reply #24 on: May 10, 2018, 02:03:36 pm »
What brand is blue banana plug for the guard cable ?
Or is this an original Fluke low emf cable?
