I'm trying to calibrate my 6612C System Power Supply.
I'm being lazy and not connecting to the rear force/sense terminals -- just until I can prove to my self that I can calibrate, then I'll use those.
I can get into Cal mode (via the front panel, or GPIB) and calibrate the voltage and high current range. However when I enter the CAL:LEVEL P1 and then CAL:DATA data value, I get an OUT OF RANGE ERROR. The calibration setup shows to use a 400 ohm R in series with an ammeter -- so it seems that the precise value of the 400 ohm can't be that critical -- I get about 40 mA. No matter whether I enter the value as 0.040, or 40.0, I still get that error.
Any ideas/help ?
