Author Topic: Choosing a 3d scanner for metrology purpose.  (Read 1646 times)
Offline ShpakTopic starter
  • Country: ee
« on: December 06, 2017, 02:41:35 pm »
I have to choose a 3d scanner which mostly will be used for metrology purpose. Which means I need to get very accurate data of the geometry of object to be scanned. However, sometimes it will be used to create good renders.
Right now I have two options.
Artec Spider which as I understand can be used to perform accurate measurements and also provides textures.
FARO Laser Tracker ION as it provides much higher precision but no textures (If I got it right). And in addition second scanner, less accurate, but good for textures. Maybe Eva or maybe something else.
I need an advise here.
Offline 3dtech
Re: Choosing a 3d scanner for metrology purpose.
« Reply #1 on: January 05, 2018, 03:10:13 pm »
Hi Shpak
The best for you is the  it provides highest precision 3d professional scanner with texture CREAFORM 3D Scanner.
Hope that's will be helpful for you  :)
The following users thanked this post: Shpak
  • Country: ee
« Reply #2 on: January 11, 2018, 02:40:27 pm »
Which exact model do you recommend?
