Author Topic: Close value population removed from R or C lot  (Read 630 times)
Offline Conrad Hoffman
    • The Messy Basement
« on: December 03, 2016, 05:05:02 am »
This is an obvious trick, unless you haven't thought of it, which took me longer than I care to admit. I had a batch of extremely good capacitors, near zero TC, but all the close tolerance parts had been removed, leaving only parts quite high and quite low from the nominal value. A double humped distribution. Then it hit me. Put a selected high and low in series to get an exact half value. Do it again. Now put the pairs in parallel to get back to the original desired value. Sure, you use 4 parts, but for standards and such it works well. For resistors, parallel a high and low, then put the pairs in series. A bag of useless becomes a bag of useful. :D
« Last Edit: December 03, 2016, 05:07:33 am by Conrad Hoffman »
The following users thanked this post: SeanB, ManateeMafia, salbayeng, lukier, carl_lab
Offline enut11
  • Love building/modifying/restoring test equipment
Re: Close value population removed from R or C lot
« Reply #1 on: December 03, 2016, 07:34:34 am »
Thanks Conrad. A very handy tip on how to make use of lower tolerance quality components.
enut11
an electronics nut from wayback...
