Author Topic: Data Logger for Legacy HP Instruments  (Read 6259 times)
Offline BudTopic starter
« on: February 17, 2017, 08:55:33 am »
This thread is for a MS Excel macro application that logs data from a few legacy HP instruments that I have. Published hoping someone else might find it useful. This work is a fork from the other thread https://www.eevblog.com/forum/metrology/3458a-logging-via-excel-macro/ which was for HP 3458A voltmeter. An early version of this work was published there but I decided to create a separate thread to not confuse the readers. Bits of code and charting was used from that other thread. However I do not have a 3458A, so I reworked the code to control my other HP legacy instruments:
  • HP 3456A digital voltmeter
  • HP 5334A universal counter
I am also planning to add HP 8753C VNA. While there may be not much to "log" from a VNA, the application can be used to grab screenshots and download/plot measured S-parameters data, as well as manage test setups and calibration standards.
The application uses VISA COM I/O libraries and a GPIB controller to talk to the HP instruments. My setup specifically is based on Win7 64, Keysight IO Libraries and a Agilent clone USB to GPIB adapter, also known as Beiming adapter, apparently named after the guy who created it. I do not have a National Instrument GPIB adapter to try but since the code is using VISA Instrumentation COM interface it should be transparent to the application and may work with other adapters, be it NI or Keysight.
The application requires two things: VISA libraries must be installed - can be downloaded from NI/Agilent, and MS Excel. My version of the MS Office is 2010, Keysight IO Libraries v17.3. The workbook includes separate worksheets for each instrument. Logging can be performed separately or simultaneously for all instruments (still started individually from each device's worksheet). Attached are the sreenshots for currently implemented instruments.
In terms of maintaining the macro and fixing bugs - I made no promises, as I am busy at my full time work, and I am not a programmer. But I will look into what I can do.
Use at your own risk. Caveat Emptor.
PS: The Excel book is attached split to two files because of this forum's attachment size limit. I used the program called 7-Zip, http://www.7-zip.org/download.html ,use it to reconstruct the archive, though WinZip should also be able to do it. Before extracting rename the files: remove the last .zip extension. I had to add it because otherwise the forum engine rejected to accept the files.
Update Feb 19, 2017:  Updated 3456A sheet with NPLC and added Math box. The Math box only does Thermistor math currently, which can be selected when Function is set to 2-Wire or 4-Wire Ohm (obviously you need a physical thermistor for it). Updated files attached.
« Last Edit: February 19, 2017, 07:41:22 am by Bud »
The following users thanked this post: bitseeker, enut11, kj7e, denimdragon, Vacuuminded, marcibalt
Offline enut11
  • Love building/modifying/restoring test equipment
Re: Data Logger for Legacy HP Instruments
« Reply #1 on: February 17, 2017, 10:32:35 am »
Hi Bud
I am using your modified version of the HP3456A XL logger that I downloaded from the '3458A' post and it works well. Have you made any changes to this version since?
My 3456A has been running hot logging data from my LM399 home made voltage Refs. Thanks for the excellent implementation.
Would it be possible to add NPLC selection to the sheet?
enut11
an electronics nut from wayback...
Online KE5FX
    • KE5FX.COM
« Reply #2 on: February 17, 2017, 10:44:55 am »
No Excel needed, just NI488.2 support:)
Offline enut11
« Reply #3 on: February 17, 2017, 11:24:41 am »
@Bud
"PS: The Excel book is attached split to two files because of this forum's attachment size limit. I used the program called 7-Zip, http://www.7-zip.org/download.html ,use it to reconstruct the archive, though WinZip should also be able to do it. Before extracting rename the files: remove the last .zip extension. I had to add it because otherwise the forum engine rejected to accept the files."
Brilliant! I downloaded the 2 Zip files to my PC, installed 7-Zip and reconstructed the XLSM spreadsheet. This is an improved logger for legacy HP instruments using a USB-GPIB interface.
A particularly nice feature in this new version is the instrument photo 'digital display' is active and updates with the data stream! Well done @Bud.  :-+
enut11
« Reply #4 on: February 17, 2017, 02:35:05 pm »
Yes, but it just nice to have all of it in a single Excel macro file. Also gives the user a possibility to massage the data the way they want right in the spreadsheet without switching to the other application.
« Reply #5 on: February 17, 2017, 02:44:50 pm »
enut11
Thanks enut11. Please keep an eye on it though, because the digital display data a is not a direct read but a derivation from it in an attempt to match what is seen on the physical display. In case of a discrepancy refer to the column with the string data because that is what is actually received.
eDIT: I will add NPLC parameter to 3456A
« Last Edit: February 17, 2017, 02:49:05 pm by Bud »
Offline enut11
« Reply #6 on: February 18, 2017, 09:18:29 pm »
Hi Bud
Another bit of useful information for me is to include a running AVERAGE VALUE for the logged data. Thankfully Excel ignores blank cells so the AVERAGE is always correct no matter how many samples are taken.
I put mine at the top of the VALUE column but it could also sit with the MIN, MAX numbers over the Graph.
enut11
« Reply #7 on: February 19, 2017, 07:44:18 am »
I have posted updated files.
Can this be achieved with the device's Statistic function?
Offline enut11
« Reply #8 on: February 19, 2017, 09:30:29 am »
Perhaps, but only for its internal memory log which I believe is quite limited.
enut11
PS. Where are the new files?
« Last Edit: February 19, 2017, 09:32:07 am by enut11 »
« Reply #9 on: February 19, 2017, 03:18:31 pm »
The new files attached in the original post replacing the old ones.
Offline enut11
« Reply #10 on: February 20, 2017, 12:16:32 am »
OK, thanks.
Well, you have done it again Bud. Very useful upgrades to the legacy HP instrument XL data logger.
What's new that I have discovered:
1) 'Monitor' switch is handy. I use it before 'Start' to suppress data logging while I set things up. Or, use it during logging to pause/restart.  :-+
2) NPLC is now selectable via drop-down. Also warns you if there is a conflict with 'Sample Time'.  :-+
3) Separate drop-down for volts and ohms is also clearer and easier to set up. :-+
enut11
« Reply #11 on: February 20, 2017, 05:13:44 am »
Thanks enut11. Monitor mode is meant for just updating the digital display without logging the data stream. Can be useful for watching the display (monitoring the measure) on the side while doing something else on the computer, hence the "monitor" name. Or as you said, when playing with settings.
Also in running mode you can change Range setting on the fly, can be handy too.
Next addition i think could be a generic command interface to write/read the device.
The following users thanked this post: denimdragon
« Reply #12 on: February 20, 2017, 03:15:54 pm »
I noticed that my Agilent clone/Beiming GPIB adapter does not re-initialize properly when the computer wakes from hibernation. It still can read the device but is unable to write to it and that may cause confusions. The adapter has to be re-connected. Be aware of this bug in the clone adapter.
The following users thanked this post: enut11
Offline denimdragon
  • "Hole charge chaser and wanna-be o-scope fixer"
« Reply #13 on: February 14, 2019, 07:16:49 pm »
How would I mod this to work with the 3457A? Also, I wonder if it would be possible to get it to add the "7th" digit into the equation  :popcorn:
"Hi there. I'm short in the hair department, do you mind if I pull a few strands from your head? Thanks!"
