Author Topic: DIY Low EMF cable and connectors  (Read 41360 times)
dl1640 and 1 Guest are viewing this topic.
Offline 0.01C
  • Country: hk
Re: DIY Low EMF cable and connectors
« Reply #125 on: August 03, 2017, 10:12:11 AM »
Ah, thanks for the tip.
Do you also have a link to the banana plugs which are all one piece and have the cross-shaped cutout?  I tried searching for those based on the description, but nothing came up.
pm your email address to me , i send the taobao link to you
Guildline Datron Fluke L&N ESI HP
0.01C
The following users thanked this post: cellularmitosis
Offline cellularmitosis
« Reply #126 on: August 03, 2017, 10:14:18 AM »
Yeah, that's a bummer!  It just replaces the characters with '?'.
LTZs: KX FX MX CX PX Frank A9 QX
Offline alm
« Reply #127 on: August 03, 2017, 11:00:27 AM »
I thought we solved this problem years ago with Unicode. But apparently Unicode is too difficult for SMF or the database setup.
You might be able to use a link shortener like tinyurl.com/ or goo.gl.
« Reply #128 on: August 03, 2017, 11:08:16 AM »
I found two plugs which appear to be the same style (one solid chunk of copper with a threaded end):
https://world.taobao.com/item/529066733817.htm
https://world.taobao.com/item/550387066144.htm
I've ordered a few of each.  When they arrive, I'll cut into one of them (or try the citric acid trick) to see if they are really copper inside.
Offline 0.01C
  • Country: hk
« Reply #129 on: August 03, 2017, 11:40:14 AM »
Try this
https://world.taobao.com/item/36025097741.htm?fromSite=main&spm=a230r.1.14.19.ebb2eb27o1fGJ&ns=1&abbucket=17#detail
0.01C
Offline 0.01C
  • Country: hk
« Reply #130 on: August 06, 2017, 12:34:45 AM »
0.01C
Offline Flinstone
« Reply #131 on: August 06, 2017, 12:47:50 AM »
Hello VoltNuts - As some of the VoltNuts live in europe and we see all these nice products on TaoBao - can someone explain the details how to order from Taobao - most of us do cannot read chinese language ... how to become member of Taobao as a customer living in europe and what are the options we have to pay (VISA, PayPal, ... ?)
Thank you for explaining this buyers process in detail
Best regards
Fred Flinstone
Yabba Dabba Doo !
Flinstone
55 Cobblestone Road
Bedrock
« Last Edit: August 06, 2017, 12:54:34 AM by Flinstone »
« Reply #132 on: August 06, 2017, 02:06:34 PM »
Fred,
My first experience was with a Taobao "agent" (it was https://taobaofocus.com/ ), which is an english-language website where you give them the item numbers (from the taobao.com URL), and they buy the items and then ship it to you.  This seemed convenient, but they tack on a ~30% fee, and then on top of that you have to pay rather expensive shipping (on top of whatever it cost to have the items shipped to them first).  This meant that the salvaged LM399 references I found for ~$3.00 each ended up being the same cost as the ~$6.00 units available on ebay, which defeated the whole point of using taobao.
Next, I used taobao.com directly.  I used the translate feature of google chrome to mostly muddle my way through the sign-up process, and creating an alipay account (which is like a chinese paypal), shopping, and placing an order.  There were a few screens which chrome didn't seem to be able to translate, and for those I had to install the google translate app onto my iphone, which allowed me to point my phone's camera at my laptop screen and perform the translation.  Additionally, there are a lot of taobao listings which have text baked into images, which chrome can't translate, but the phone app can.
In general, there's a very big "I have no idea if this is going to work" aspect to all of this, and you have to be willing to take a risk.  For example, my first order was about 5 different items, 3 of which have shipped, and 2 of which have had no response from the seller in about 5 days (pity, one of those was an LT1088 for only $18 -- perhaps that was too good to be true).
Best of luck!
The following users thanked this post: Flinstone
Offline Flinstone
« Reply #133 on: August 06, 2017, 04:16:01 PM »
Hello cellularmitosis, VoltNuts,
                                              Thanks for guiding us in the right direction ...
I have a question about the payment scheme - I suppose that Alipay is linked with buyers Visa or bank account - can you comment ?
Is there something as AliPay protection if goods do not show up - like there is with Aliexpress ?
Thanks for sharing your Taobao user experience ...
cheers
Fred Flinstone
Yabba Dabba Doo !
Flinstone
55 Cobblestone Road
Bedrock
« Reply #134 on: August 06, 2017, 04:19:32 PM »
Yeah, mine is linked to a Visa card.
Not sure about what sort of protection they have.  I'm actually discovering what ebay's process is right now -- I won an HP 3457A for $150, only to have it apparently delivered to the wrong address by fedex... :(
Offline onemilimeter
« Reply #135 on: August 13, 2017, 02:32:55 PM »
Hi...
I found this Teflon (PTFE) cable (shielded, silver plated, 19x0.2mm) from Taobao...
https://world.taobao.com/item/525683103258.htm
The seller wrote it's imported from Japan, manufactured by Junkosha Inc (http://www.junkosha.co.jp/english/)
The outer insulator (brown color layers) is Teflon/PTFE... but I'm not sure about the inner insulator (white color and black color layers)... if I buy it how can I test to tell if it's Teflon/PTFE?
Thanks
« Last Edit: August 13, 2017, 02:40:45 PM by onemilimeter »
« Reply #136 on: August 13, 2017, 07:17:51 PM »
I think you could use an electrometer to compare leakage against the same length of some CAT5.  What is the most sensitive current range you have available on your instruments?
Offline Andreas
« Reply #137 on: August 13, 2017, 07:22:29 PM »
why not make a simple test with a soldering iron.
Teflon should withstand around 200 deg C.
With best regards
Andreas
The following users thanked this post: onemilimeter, cellularmitosis
« Reply #138 on: August 13, 2017, 07:28:27 PM »
bigclive has an interesting way of testing finely stranded wire to see if it is actually copper, or just copper coated aluminum (which apparently is a common cost-saving trick in the ebay junk he loves to review).  If you hold the flame of a lighter against the strands, copper coated aluminum will crinkle up like a dead spider, but pure copper is basically unaffected.
The following users thanked this post: onemilimeter, macboy, CalMachine
« Reply #139 on: August 13, 2017, 09:39:06 PM »
I may have access to a Keithley 2002. Can this instruments do the job? Thanks.
« Reply #140 on: August 13, 2017, 09:52:27 PM »
Strip an end and use a lighter. If it burns it is PVC or some other plastic, and if it just chard and makes a noxious smoke it is PTFE.
Likely though if the outer sleeve is PTFE the inner is as well, as that type of cable is common in avionics as a data wire or shielded cable for low level signals.
« Reply #141 on: August 16, 2017, 01:07:25 PM »
Welp, the first set arrived.  It looks like they are gold-plated brass, although they almost feel too light to be brass.  (I filed off the outer plating, and the surface and shavings have the appearance of brass).
I wonder if there is an easy chemical test to check for brass?  I know that copper will turn some acids bright blue...
« Reply #142 on: August 16, 2017, 01:13:00 PM »
So after watching this Transmille video where he demonstrates using a null voltmeter to directly measure a thermal EMF, I decided to take the plunge and bought an HP 419A on ebay.
https://youtu.be/KiYhEP6m7Pc?t=1m23s
In a few weeks I hope to be able to measure thermal EMFs directly!
Offline 0.01C
  • Country: hk
« Reply #143 on: August 16, 2017, 01:18:39 PM »
buy keithley 155 or Fluke 845 is better
0.01C
Offline ManateeMafia
« Reply #144 on: August 16, 2017, 01:22:41 PM »
My money says it's brass. I am more interested in finding out what they used for the external plating.
A null meter is invaluable and at least the seller gives a 14 day warranty. You may want to see what kind of chopper amp was used but I have recently taken photos of an ESI 801 and it used the HP 419 as the null meter. very nice looking inside.
« Reply #145 on: August 16, 2017, 01:35:16 PM »
Yeah, I did a bit of homework.  Those are nicer units, but they are out of my "splurge" price range (they are $200+ on ebay at the moment).
There are a lot of Leeds & Northrup models for ~$50, but their lowest range is 1mV.
The 419A's lowest range is 3uV, and the price was right, so that's the one I settled on.
(I think a fun project might be to see if you can get a Leeds & Northrup unit for $25 using "best offer", then gut it and install Conrad Hoffman's null detector circuit from his mini-metrology-lab article series)
« Reply #146 on: August 16, 2017, 01:40:19 PM »
Hmm...
Apply a small amount of hydrochloric acid to an area of the brass. Test only a small area because the test is corrosive. Unlike some metals, brass turns pink when it is tested with hydrochloric acid.
via http://ourpastimes.com/identify-brass-metal-8529918.html
« Reply #147 on: August 16, 2017, 01:52:48 PM »
I bought some copper spade lugs from China ,not bad.
Great find!  I've been searching for unplated copper spades, but haven't had any luck.  Can you reveal a link to where you found these?
« Reply #148 on: August 16, 2017, 02:03:41 PM »
Very interesting Echo88!  I think I'll try that myself.
Would something like this work?  Powdered food-grade citric acid?  https://www.amazon.com/gp/aw/d/B00EYFKKZC/ref=sxts_sxwds-tsp_1_a_it?ie=UTF8&qid=1501683294&sr=1
TiN, 0.01C, can you guys post a link to the taobao seller who sells those binding posts?  I'd like to order some.
My first victim to go into the citric acid bath was a cheap "logico" banana plug, which appear to be a clone of Nakamichi banana plugs.
A few days into the acid, the body of the connector started to take on a reddish hue, and I thought they might actually be copper.
However, after about another week, and after taking them out of the acid for a while, they were a much darker, brownish color.  Filing away the body reveals what looks like brass.
« Reply #149 on: August 16, 2017, 02:54:44 PM »
I took interest in the "logico" plugs because I was trying to get away from plugs which had a loose-fitting free-spinning contact barrel-spring.  The logico plugs were of a style where the contact spring was attached solidly to the body, which I thought would be better for precision measurements.
Then, while searching for unplated copper banana plugs, I came across the plugs marketed at audiophiles:
http://www.douglasconnection.com/Furez-TSTSB60NP-Bare-Copper-Banana-Plug-Connectors-Pair-FZTSTSB60NP.htm
I liked the design of these plugs even better, as they were a single, solid piece of material, and it seemed there would be even more surface area in contact with the DMM's socket.  They also claimed to be tellurium copper, so even though they are priced for audiofools, I decided to order a pair for use as a low thermal EMF "benchmark".
Then, just this evening, I stumbled upon the fact that this style of connector has a name.  If you search for "BFA banana", you'll find plugs like this.
https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Delectronics&field-keywords=bfa+banana
https://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=bfa+banana&_sop=7
https://www.aliexpress.com/wholesale?&SearchText=bfa+banana
Taking it a step further, you'll find plugs marketed as "low mass", which appear engineered to have a little mass as possible.  This also seems desirable for minimizing thermal EMF's.
I managed to find an ebay seller who sells unplated copper "low mass" BFA-style banana plugs, and I've just ordered a few.  They are just under $3 each, so not cheap but also not audiofool-priced.  I'll keep you posted!
http://www.ebay.com/itm/162631332431
