Hi all,
I have a Keysight DSO X 3024A. It has a built in waveform generator. Unfortunately I wasn't able to find in the datasheet the output current when I apply the waveform to a load, supposed that the load is matched. I know that I can choose between a 50
load or a 1M
one but nothing is said about the current.
How should I deal with this issue? The current is important because I have to be careful with the amount of power that I am injecting into the load
Thank you
