It seems to be in spec for an "AQ". What are the markings on the chip?
They have 3 line markings. The 1st two are lined up with the AD logo. The 3rd is under the logo. I don't have hardware that allows me to get a usable photo.
1 - AD588BQ / 0828 / E73245
2 - AD588BQ / 0828 / E73245
3 - AD588BQ / 1028 / E73245
4 - AD588BQ / 0828 / E73245
It has been a while since I looked at markings on cerdips. They could well be re-marked.
Are the outputs on the PCB correctly kelvin sensed or is there a large voltage difference betwen output GND and Gnd Sense In+ (pin 9) of the device?
The outputs are not correctly kelvin sensed. They are joined under the chip. There is no discernible difference between output GND and pin 9. They are almost co-located on the board and are both joined to the ground plane. I do get 150uV(ish) difference between pin 6 & pin 1 (unbuffered output vs buffered output - measured both in reference to gnd and between the pins)
I thought that may have been the additional 10M load applied by the meter, but I chucked a 1M load on there and got no change, so the output buffer appears to have a 150uV(ish) offset.
I'm also seeing 110uV between GND and pins 8/10 which if I read the schematic right would imply the internal ground is not at system ground, but measuring between pin 1 and pin 8/10 gives me the same reading as pin1/gnd, so maybe I'm reading the chip schematic incorrectly.
It seems to me that the largest error source in this plan is the Caddock voltage divider, +- 30ppm/C.
So I would worry about that more than current noise.
OP, do you have a schematic? What are your requirements?
Good question. I have no schematic as I'm still spitballing. Getting a stable 30V is my first step. I figured I'd buy 4 references and pick the best 3.
I already have the divider, so the 3, .3 & .03 outputs are next. I'm also considering tapping the references to allow me to switch using 10, 20 & 30V as a base for a bit more flexibility. I've been using a Tek PG506 but while it is flexible enough, it's also a bit drifty.
My requirements are to provide a short to medium term stable set of voltages 30mV to 300V (I'll deal with the 300V later, but at the moment I'm looking towards 30 REF5010 in series as a shunt regulator) as a transfer standard to periodically calibrate (not adjust) a pair of HP3478a against a 3457a. I'm chasing a short term (stable temperature ~10 to 30min) of a couple of PPM (<10 if I can manage it). If I can get <100PPM over 24 hours with a couple of degrees C ambient change then I'm doing better than I need.
Stability rather than accuracy is the aim here.
