Good repair description ..
.. for the case that my own FRS will stop operation.
Next step would be to mount the Rb standard on an appropriate heat sink, if not already done, otherwise you'll reduce its lifetime.
Calibrating the standard against a GPSDO would be the next step, by using an appropriate T.I. counter with 1ns resolution at least, and monitoring the phase difference over hours using TimeLab, that would be my proposal.
Frank
