Can you post a photo from all angles?
Often, Efratom units comes in larger case with buffer amp, etc, and INSIDE IT is the real Rb oscillator. While I don't suggest randomly taking it apart, some of us can often recognize placement of connectors, etc, and suggest you should do so.
