Recently picked up a 8842a. DCV seems to read OK, but the 2-wire ohms readings are completely out of whack.
Went through troubleshooting with the service manual, and narrowed it down to the Ohms Current Source section of the schematics.
- Supplies are OK, no ripple and voltages are within range.
- -7.0V Precision Voltage Reference is on the mark.
I then tested the first stage of the Ohms Current Source. The manual says to connect a 2k resistor between Reference Low and U402-19. I checked the voltage across R401 and it is correct (7.0V). Checking the output of the op-amp (U401-6), I only read -1.0V (should be -4.0V). So I noticed that U401 is an OP07, easy to find, but the JFET Q401 I cannot figure out the manufacturer's part from the markings. I attached a photo of the circuit and the markings on the JFET. Do you think I can use any n-channel JFET in place of it (with the proper voltage specs)? I plan on removing the JFET and testing it.
Also, another question, what's the reason for some of the JFETs in the circuit (Q405-Q407) to have the drain and source shorted? I don't think I've ever seen that before.
Thanks for your help!!
