Author Topic: Help on calibrating a Multimeter UT55  (Read 2047 times)
Offline maujavier91Topic starter
  • Country: ve
« on: July 11, 2018, 02:42:35 am »
Hello, i have a Uni-T UT55 and is currently giving wrong readings i think the calibration is completely off, as it measures negative voltages in the VDC scale having the test leads in the air, this also occurs in VAC, measuring -230Vac in the air, or measuring negative frequency, no reading is correct, also measuring the resistance touching both test leads gives negative reading in some scales, is this a calibration error or could some part of the circuit be damaged, if it is a calibration error, how could i return it to normal readings. I attach the schematic i found online.
« Last Edit: July 11, 2018, 02:51:32 am by maujavier91 »
Offline mjhvanvliet
Re: Help on calibrating a Multimeter UT55
« Reply #1 on: July 11, 2018, 12:37:54 pm »
Have you tried to change the battery? I think the calibration is not your problem, but an empty battery or broken meter.
The IC used is ICL7106: https://www.intersil.com/content/dam/Intersil/documents/icl7/icl7106-07-07s.pdf
